My Panasonic KX-TGE270 phone used to show caller ID and even talker ID but stopped. I am subscribed through my home phone provider. Can you help me troubleshoot?
SOURCE: Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
SOURCE: want to delete caller ID from my Panasonic KX-t7730
This is just a guess, because it works on my 848.
While you are displaying the CID directory, press the TRANSFER button. Repeat as necessary.
Carl
SOURCE: caller Id on phone
If you have it on other Panasonic phones, it should be automatic if the phone is made to ring.
If you don't have it, you need to call your Panasonic dealer. It requires hardware and programming.
Carl
