Question about HP Photosmart 7850 InkJet Printer
Red light on my hp photosmart 7850 keeps flashing
Hi there light on my hp photosmart 7850 keeps flashing .i just got the ink filled 3 days ago and its loaded up with paper
Re: red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Posted on Nov 08, 2008
Hi guys, spent about 2 hours on the phone with HP Germany without a result. They told me it is something in the printer itself and its not possible to resolve. My printer is still printing but not automatically. I can send files to the printer but have to push the OK and left arrow button on the printer at the same time to release the print. Be carefull though, at the end of the printed document, the printer will also print a test page. You can avoid wasting toner and paper by pushing end X (delete button on the printer). Doing that it will only feed an empty page. Not a nice solution but at least I can still use the printer although not in automatic mode.
Posted on Nov 09, 2008
0 characters
3 Points
HP Photosmart Printer 7850 I would like to print a self-test page because I want to know if the problems are with the printer or the applications I cannot install any windows software because there is only...
Here's how to print a self-test page.
HP Photosmart 7850 series printers
  1. Make sure plain paper is loaded in the In Tray and the printer is on.
  2. Press and hold the Select button.
  3. Press the Left arrow button once.
  4. Release the Select button.
Jan 04, 2011 | HP Photosmart 7850 InkJet Printer
HP Photosmart 7850 Service Manual Required
hi i brought hp photosmart 7850 of ebay please could anyone tell me how many leads should there been with it
Nov 12, 2009 | HP Photosmart 7850 InkJet Printer
! keeps flashing
Check on the error message that appears on both your monitor and printer....most of the time you run out of paper, a paper jam, or a low ink cartridge....whatever message that is it needs your attention!....cheers
Apr 11, 2009 | HP Photosmart D5160 InkJet Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
INK Color is off
That's usually a sign of a cartridge that is running low on ink. Especially if it happens in the middle of the picture. Also, make sure that you have HP Premium Photo paper when printing photos. Also make sure that you click the properties button on the print dialog screen and choose the correct paper type. It will make a much better picture. You cn find more information on the types of paper on page 7 of the manual.
Hope this helps. Please remember to rate this information.
Oct 07, 2008 | HP Photosmart 7850 InkJet Printer
Ink issue
Normally if it's an ink cartridge problem, you will see there is a small cartridge symbol being shown in the right hand side window. If there isn't a cartidge symbol then it doesn't need a new cartridge. Normally when the red light flashes, it means there is some other problem such as paper jam or no paper! To change the cartridge, open the top of the printer, you'll see the cartridges on the right hand side, they should hopefully just pop out when you pull them GENTLY. To insert a new cartidge, follow the pictures shown and make sure you hear a 'click'.
I am not a techie at all so I hope this helps
Oct 06, 2008 | HP Photosmart 7850 InkJet Printer
HP Photosmart 7850 InkJet Printer Logo
2,263 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
