Question about Tricity Bendix Washing Machines
Every time I turn on the appliance it blows a fuse
    President:
  • 704 Answers
A washer requires a dedicated electric outlet to operate properly. It is possible that the plug you have is part of another circuit and has some other high ampere drawing devices connected to it. Check to see if any other items are affected when the circuit trips (or fuse blows).
If you truly have actual fuses instead of ciruit breakers, make sure the fuse you are replacing is a slow blow type rated at the proper amperage for the circuit.
If you have circuit breakers, you might have to have a separate 20 amp dedicated branch circuit added to power the washer. (USA/Canada)
Without further details of the specifics of your situation, that is the advice to check first.
Posted on Jul 28, 2009
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
WHIRLPOOL LEC8858EQO
If the drum is turning and air is blowing then the most likely causes are thermal fuse trip, thermostat fault or heater fault.
Some good points mentioned on this site.
http://wiki.answers.com/Q/Why_wont_my_whirlpool_electric_dryer_heat_up
Discussion about thermal fuse on this site.http://www.appliancejournal.com/appliance-parts/whirlpool-appliance-parts/whirlpool-dryer-thermal-fuse-3390719-64/
May 05, 2014 | Dryers
When i plug in my oreck steam it mop, it keeps blowing the fuse
Make sure no other appliance is running at the same time. Some other appliance on the same house line is causing the fuse to overload. Example: If we have the space heater on in the bedroom and my wife tries to use her hair dryer then the fuse blows as they are both on the same circuit.
Aug 26, 2013 | Oreck Vacuums
Car blows fuse when head light turned on
If you continually blow a fuse when using a high-amperage appliance, you may need to change the rating of the fuse itself...more?------------------------------------------------------------------------------------
Auto HID Xenon Light
Jan 22, 2013 | 2003 Kia Spectra
I have Kenmore microwave/vent combo. Vent and light still works but every time I turn on the microwave, it will blow out the fuse. What can be the problem?
There's a Hot-to-Neutral short in the microwave that is revealed whenever you turn on the microwave.
FIX: fix (or replace) the microwave. The fuse blowing is preventing any fire that would otherwise
develop.
PROBLEM: small appliance manufacturers don't offer for sale replacement parts. So, even the
handiest repair person is thwarted when a part breaks.
WHY: Small appliances are considered to be "throwaways" by US consumers - few consumers have repair skills, and small appliances are cheap, and therefore simply run until they stop/malfunction/blow fuses/pop breakers, and are then replaced. Major appliances are those expensive enough to
justify selling/distributing replacement parts - washing machines, dryers, cars, TVs, etc.
TO TRY: give your microwave to the nearest handy repair guy/kid in the neighborhood for repair, and realize that the chances you'll get back a working microwave are slim to none.
THE FIX: You're forced by your fellow consumers to do what they do - buy a new microwave.
Jun 13, 2011 | Kitchen Ranges
My maytag dishwasher apparently blow a fuse in Fuse Box. I then throw the switch it worked ok, next day or two my wife try to start the dishwasher it would not turn on. I bought new fuse to put in...
It seems you may have an Electrical Insulation Break Down fault with your machine.
My suggestion would be to get a Registered Appliance Technician to test the internal circuit of the machine before attempting to switch on the appliance or rectify any fuses.
The appliance needs to be issued with a (PAT) test first to determine if the appliance is safe to touch when applying power to the machine so you dont electrocute your self.
Once the (PAT) test has been applyed then the technician can visually inspect the high voltage internal parts that could be the result of the insulation break down.
I strongly suggest if any kitchen appliance trips the main fuse for any reason I would recommend not trying to change any fuses as this second atempt to reboot the machine may have blown the machines 'Power Control Module'!
Apr 30, 2011 | Maytag 24 in. MDB9150A Built-in Dishwasher
It will not turn on
first of all you need to check probable causes,make sure there is power to the electrical socket , try something you know that works, if this appliance works the next step would be to try the fuse in the plug , replace old fuse with new and to be sure to use correct amperage , too small it will blow fuse too large it could blow appliance. If this fails then its sure to be a component of which a competant electrician / service repairer should be sought.
hope this helps.
Jan 13, 2010 | Vacuums
#8 fuse blows as soon as replaced
What ever the fuse is going to has a "direct short" in it. Either somewhere on the wire between the fuse and the appliance it is hooked to there is a bare spot (a place where the wire insulation has worn off) and it is making direct contact with a ground (car body) or the appliance the fuse is hooked up to has been damaged, and has shorted out, and needs to be replaced.
Solution: trace the wire from the fuse to the appliance looking for bare wire, if you find that cover it with electrical tape and problem solved. If not then unhook the appliance and replace the fuse. If the fuse does not blow then the appliance is bad and replace the appliance.
Apr 26, 2009 | 1990 Mercury Grand Marquis
We have a Bunn coffee maker manufactured in 2006. Any time we try to use it, it blows a fuse
You didn't mention which fuse it was that blew; I assume you mean a house fuse, not the Bunn's.
Since you mention a fuse rather than a circuit breaker, again, I assume this is the screw-in type that must be replaced each time it fails.
Check your Bunn for the rated power consumption; it should be shown somewhere on the machine and is likely somewhere between 1000 and 2000 watts.  You need to find how much current the machine is drawing.
Divide the given wattage by your line voltage which is probably (if in the US) ~120 Volts. For example: (from the Bunn) 1200 Watts/120 volts = 10 Amperes
That means that when the Bunn is heating water, it will need 10 amps just for itself.  If, for example, you have a microwave oven using that same fuse that has a rating of 1000 watts power to cook with, it will actually draw ~ 1400-1500 watts from the wall plug.  Again, 1500 Watts/120 volts = 12.5 Amperes
Now we have a total of 22 1/2 amps of current if both are operating at the same time or if any other appliance such as a toaster (also draws a bunch) is being used, you will most likely blow a 20 amp fuse if not instantly, perhaps after a few minutes.
Fuses are designed to blow in a few milliseconds if hugely overloaded or to be patient for a minute or two if the over-current is mild; say 21 amperes.
Over-fusing may be dangerous since the fuse rating is related to the gauge of wiring in the circuit it protects. This means that you need to move the Bunn to a different circuit so you don't accidentally exceed the fuse rating with two high-powered appliances if turned on together.
Sep 28, 2008 | Bunn BT10B Coffee Maker
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Washing Machines Logo
131 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
