Question about Whirlpool LHW0050PQ Front Load Washer
Loud noise during tub draining - Whirlpool LHW0050PQ Front Load Washer
  • Whirlpool Master
  • 3,463 Answers
If it is only niosy when draining, then I would check the pump or filter for something caught in it.
Please rate my solution.
Thanks.
Posted on Jul 28, 2009
Airplane noise during spin cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 14, 2015 | Washing Machines
My ultimate care 2 washer is full and makes. a loud noise when I turn it on. Nothing happens. It doesn't drain
Aug 06, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
FLC271W2 washer squeal during wash cycle
May 23, 2014 | Frigidaire Washing Machines
Loud grinding noise when drum turns
Apr 20, 2014 | Asko Washing Machines
During spin cycle loud clunking noise
Feb 16, 2014 | Frigidaire GLTF1670A Front Load Washer
Thumping and banging during the high speed spin cycle
Feb 08, 2014 | Frigidaire Washing Machines
Hotpoint washing maching making a loud noise on spin how to get in to it
see this possibles causes:
During fill only
air gap device, crack see the diagram+tube can be crack+inlet spout break.
During drain and spin only
check the hose, allternative the outer tub
All the time: main tub +pump+outer tub defective replace
see the diagram
Jun 18, 2012 | Bosch Washing Machines
Their is a loud scraping noise when the washer begins the cycle. I have cleaned out the filters and there was no noticeable lime build up nor debris. The tub spins freely but the noise is persistent. We...
Have you check the pump, all front load washer drain before filling. If you have coins or foreign object inside pump the can be the cause of scraping noise. I would also check the tub for nails or object that can poke through and tub on the outer tub during rotation. Most of the time its a foreign object in the pump issue. Good luck..
Jul 11, 2011 | LG WM0642H Front Load
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
193 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
