Question about Ovens
  • 248 Answers
You probably have a weak oven igniter. It's the thing you see glowing. UNPLUG UNIT and replace igniter.
Posted on Nov 22, 2007
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
May 18, 2011 | Ovens
First pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit. Now if it doesn't light, sometimes you can just move this a little bit and get a little bit gas flow through there and in this case, it did light properly. And then now test the oven. Push in on the valve and turn it.
Kindly rate my help+++ Thank you
May 09, 2010 | Ovens
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Oven burner will not ignite
try this web site for operations manual.
Sounds as if the thermocouple may be bad. It is enough to keep pilot lite but not enough to open safety valve. Some of their ovens have a "Mercury Switch" instead of a thermocouple. Look behind the kick plate. It will have a white ceramic base and have 2 wires going to it. The end sits in the pilot same as thermocouple. If there is a pilot valve, make sure that once the pilot is lit, you turn it to "on" if the position is available. Lots of options on these ovens as they custom build alot for certain companys. Check this out and let me know.
May 22, 2009 | Southbend S560DD (Gas) Oven
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Mar 02, 2008 | Ovens
Ovens Logo
106 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
