Vcr's commonly get dirty heads that cause a blue or snowy screen and no sound in some cases. In my experience the rental tapes were common point of trouble especially when you consider the amount of machines that were deployed in use back in those days. Today people run into less issues because they have there own collection and put them to good use. In order to deal with some people's problems there are three approaches to cleaning heads, the first option is to use a wet tape with the provided fluid usually two or three drops will do and run it for ten to twenty seconds. The second approach is use a dry tape with same amount of time as outlined above. The third approach is get a blank store bought tape "T120 2hours" set the vcr to sp and run the tape from beginning to end, this is a good way if you want do more of a deep clean to remove difficult dirty particles that refuse give way. I find the dry tape will give less problems when cleaning and less chance of shredding and easier for people who don't like taking vcr's apart.
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit 2) Insert VHS tape 3) Insert DVD-+R or DVD-+ RW 4) Using remote, press VCR 5)Using remote, press play then pause the tape where you want to start recording. 6)Using remote, press DVD 7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
If the vcr has two scarts connect the DVR player to one and select that imput. Watch the program using the the other scart connected to the TV. Press record on the vcr and then start the DVR player going. If it doesn't have two scarts use the front panel jacks to connect the DVR player.
The only time you won't be able to record a program is if somekind of anti-copy system is employed.
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Make sure you are giving the VCR a signal.
If using a RF source (cable or antenna), make sure the VCR's tuner is set up for the right type and channels.
When trying to record put the TV's input to the VCR to make sure it is getting what you want.
