Question about Stoves Dishwashers
Dishwasher does not pump water out at the end of it's cycle
    President:
  • 704 Answers
First check that there isn't anything blocking the drain area inside the bottom of the dishwasher. Sometimes plastic wrap, a small Tupperware, etc. top gets sucked against the drain and blocks discharge. If nothing is there, (look really good, by getting out as much water as possible!!!). If nothing there, see if you have an "air-break" installed at the kitchen sink, this prevents backflow from the sink drain back into the dishwasher, check it by removing the decorative cover and see if it is clean and has no obstructions blocking water flow.
Another thing to check, is if you recently had a new disposal installed, it's possible that the dishwasher inlet was never "punched out" to allow for the dishwasher to drain thru the disposal. If none of those, continue with the investigation!
Check to see if some broken glass might have worked its' way into the drain area, beneath the drain discharge guard. You'll have to remove the cover, some are just clipped in place while others have a screw holding them in place.
If still nothing, it is possible that something has worked its' way all the way into the discharge pump section and you'll need to remove the dishwasher from under the counter to get at the pump section.
Normally when the dishwasher is in the pump out sequence, you can hear the pump motor and impeller spinning, if you can't, then proceed with removing the dishwasher and disconnect the power or shut off the breaker to it. It is quite possible that something has jammed the discharge impeller and is preventing pump out. Again, if you can hear the motor and impeller running, it could still have an obstruction. Bucket and towels will be needed to soak up all any water that you couldn't remove before pulling the dishwasher out from under the countertop.
If there is no obstruction in the discharge pump section and the discharge value (usually a simple rubber flap) is moving freely, then it could be the pump out solinoid (an electronic valve that opens the discharge port for pumping out water when the dishwasher is done washing and is signaled to drain. You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working OK. You'll need to reconnect the power, water inlet and discharge (drain) lines first to check this option.
Posted on Jul 28, 2009
  • 116 Answers
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Posted on Mar 11, 2007
SOURCE: nautilis ge dishwasher does not pump all water out aT THE END.
how do you fix it?
Posted on Nov 30, 2007
aborcass
  • 2651 Answers
SOURCE: Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Posted on Feb 26, 2008
  • 2976 Answers
SOURCE: Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Posted on Feb 02, 2009
stephanos18
  • 144 Answers
SOURCE: dishwasher is stuck on the pump cycle trying to get rid of water
The machine is in flood protection mode. cheers
Posted on Mar 27, 2009
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Kenmore Elite Dishwasher doesn't pump all the water out at the end of cycle
How much water? Does some drain out. If so its usually a dirty filter. Some Dishwashers have several filters underneath the bottom sprayer. Here is a link that may help http://www.managemylife.com/mmh/articles/authored/video-when-to-clean-a-removable-dishwasher-filter Also this link put in your model number and view how to clean your specific dishwasher. Hope this helps.
Sep 14, 2012 | Dishwashers
Dishwasher doesn't pump the water out at the end of the cycle.
clog in the unit . check the drain hose. disconnect the hose then drain machineinto bucket. then check the drain pump to see if the pump is pumping or clogged.
Mar 13, 2010 | Bosch Dishwashers
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
At the end of each cycle there is a puddle of water at the bottom, it doesnt sound like its pumping properly
Solve at the end of each cycle there is a puddle of water at the bottom, it doesnt sound like its pumping... (More)
Aug 19, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Water does not drain
Hi
You can :
Check for hose kinks or food plugging drain hose. Start at the drain port exit
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check timer for not letting the dishwasher pause. ( not all dishwashers )
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
Water won't pump out at end of cycle
there could be a block in the outlet pipe
regards
and please rate us
Nov 28, 2008 | Kenmore 24 in. 17039 Built-in Dishwasher
Motor problem??
have you checked the pump / motor belt?
Dec 18, 2007 | Tecnik TDW2677 Built-in Dishwasher
Nautilis ge dishwasher does not pump all water out aT THE END.
the fill valve may be contaminated with debris that makes it heavier so it floats lower in the water and tells the unit the water is gone when it's not.
Nov 25, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
286 people viewed this question
Top Stoves Dishwashers Experts
Owen Barnes
 Russ Hill
Russ Hill
Bill Boyd
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
