Question about Kenmore 63792 Microwave Oven
Need part- white vent at top
Hubby pulled it off prior to looking to see if it was screwed on...sure enough it was, key word 'was' so I've been looking online for this part to no avail....any suggestions?
    Scholar:
  • 117 Answers
Sears will have the part. Might be pricey though
Posted on Jul 29, 2009
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
The keypad is physically loose and seems to have lost connection. Only the 2 and 7 beep and connect, nothing else works including the vent and light.
well there is a ribbon cable that attaches the key pad to the control board. it will require removing touch panel to examine. if i remember correctly you have to remove the top grill cover usually having 2 or 3 screws.. they will either be hidden inside the luver portion right above the door or actually coming down from the top edge of the microwave... remove the top grill and then you should have a screw holding the console /keypad in place... make sure unit is unplugged while doing all this.. once you get screw out lift strghit up as there are hook latches on this to hold in place and then pull out. check ribbon cable coming from keypad to control board... if that all looks good then you have a bad touch poad and you need to order a new one... usually can locate the parts @
www.sears.com then hit the parts direct link up top of page... it will ask for your model number so have it ready and then in the right box pull down menu and hit model... a parts diagram will come up and pick the area control panel and it will give you a part number and prices as well as availability....good luck to you
Jan 19, 2011 | Jenn-Air JMV9169B Convection/Microwave...
Changing interior light on GE jvm1790
1. Unplug Oven
2. Unscrew 2 screws on top front of oven
3. Pull of front vent (might need a little force the
first time but not to much or you will crack
plastic)
4. Unscrew screw facing you near the front that is
attached to metal plate on bottom of opening
behind the vent.
5. Pull out metal plate (box) carefully not to
damage any wires.
6.Bulb is in this metal box, pull out old one and
press the new one's prongs into holes (be
careful and gentle the bulb breaks easily,
don't try to pull it back out to see if it's all
the way in or you will most likely pull a
prong out of the bulb)
just firmly press bulb
into place.
6. Screw metal plate back in place.
7. Plug in oven and test bulb.
8. Unplug oven again and put vent back on with
the 2 screws.
9. Plug in, set clock and your done.
The first time I opened it up was to look for the bulb. The vent needed a little pulling to come off. The second time (to put in new bulb) it came off easier and whole thing took about 5 minutes.
Hope this helps.
Just in case: I am not a professional nor claim to be. This is based on my own experience. Yours may differ. Unless you feel totally comfortable you should contact a licensed electrician or an authorized service agent.
Oct 18, 2010 | GE JVM1790 Convection / Microwave Oven
My whirlpool microwave was hooked up but doesn't seem to be venting out the roof. It has a vent running from the top of it through a cabinet and out the roof. What might be blocking the venting process?
the fan motor needs tobe turned around take screws out of top front remove front fan grill pull out fan assibliy and turn around. this will pull air out of your house
Sep 21, 2009 | Whirlpool MH7140XF Microwave Oven
Change Fuse Whirlpool Gold GH7155XHS1
no the control does not come off from behind.
what you will find is the top vent grill has to come off first. it has 2 phillips screws that hold it to the top of your unit.
you will find 4 screws on the top, go ahead and take all 4 out and then pull the grill out from the top and hinge outward to remove/ once the grill is off, then there is 1 more phillips screw that holds the control board/ touch panel to the frame. remove and then lift up then out on the panel.
now that you are into the unit, make sure you have UNPLUGGED it first. the fuse is about 1 1/4 inch long white ceramic material with metal ends. you can find a new one at a radio shack or get one online for your unit. r/s has them for cheap and if that allows the unit to run again, great, but...
there was something that caused the fuse to go bad. so dont be surprised if you need a diode or capacitor to fix why the fuse went bad.
Feb 02, 2009 | Whirlpool GH7155XHS Microwave Oven
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
Can't remove a1985 GE Microwave Mode3l jvm61001 fro0m the wall.
this microwave oven slides out of its casing. here's how: first shut the power to the unit by the breaker from your main panel. on the mw oven remove the underneath rightside vent filter. unplug the large white connector that you see in through where the filter was . Dont break it. its locked and keywayed. next remove the top front plastic horizontal louvered front vent by one phillips screw on each end of the vent left and right. then remove the next two phillips screws you see under where the vent screws were. then remove the 3 shoulder screws underneath the front edge of the case bottom then slide that piece of **** oven out of its casing. I'm sure you will know what to do next. Good luck!!
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
Jul 11, 2008 | Kenmore 62622 Microwave Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
GE Profile XL 1800
It's a little more complicated than Leo2 suggested but the general concept is correct. *NOTE: Turn off power to the microwave first before servicing it!
At the top of the microwave there are three screws.
Remove the three screws and slowly pull down from the top to get the plastic airvent out of your way.
You will notice a plastic vent with two screws. Remove the forward screw and then pull from the top of the vent to access the rear screw. Now you have access to a metal plate above the fan assembly. Remove the screws at the leading edge to lift up the plate. You don't need to remove it, just lift it up!
Now you have access to the metal box over the lightbulb. Squeeze the box and the box with the light bulb inside come out as one unit. You'll know you have the correct bulb as it is attached to two white wires. Remove the bulb. Should be a halogen 120-130 volt with 35 watt brightness. Remember, halogen bulbs should never be handled with your bare hands. The grease from your fingertips heats up and the bulb burns out prematurely. Always handle these bulbs with rubber or cloth gloves. They are expensive little sucks ($7.79 at Home Depot) so handle them with care!
Good Luck ...
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 63792 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
