Question about Frigidaire FAH085N1T Air Conditioner
I have the same problem--what foam is to be removed???
The internal packaging on the new AC I bought that has to be removed is unclear. Should I cut out all the hard foam after I remove the front panel.Model FAM 157S1A Frigidaire
2 Suggested Answers
SOURCE: What is internal packaging and what needs to stay? Frigidaire AC
it is not obvious!! i just bought the same unit.the picture is not clear! the foam behind the radiator in the front looks like it is a part of the unit and should not be ripped out.i tore mine out and messed up the unit .it is either for noise reduction or a cooling box for the air ?? the manual is not clear.also why would they make a unit that you need to tear apart by removing factory installed assemblies to get at foam. this foam is engineered to fit perfectly around all the peaces and i say it stays! this is a very crappy problem that i blame the producer for not making crystal clear. i worked for a major tooling co for most of my life and i have never seen anything so un clear with the info they provide.
Posted on May 02, 2010
Power supply was cut
you can buy a new power cord or you can use another wire to replace the cord. just buy the same size then you will need to remove the rear cover to access the internal. and then the old cord must be removed from the ac terminal pin and the assembled wire with plug that you buy can be replaced. you can directly re soldered the end of the ac wire at the pcb for ac supply.
Aug 16, 2012 | Mitsubishi WD-57732 Projection Television
How to change foam on handles
See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website.
And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
http://www.ehow.com/how_6730072_change-bike-grips.
html Bike grips and stroller handles work the same way.
I just used this post on e-how to replace my maclaren triumph foam handles.
Works like a charm - and it's sooo easy!! :)
Sep 26, 2010 | Bugaboo Cameleon - Tailored Fabric...
We have a Emerson Quiet Kool air conditioner in a camping trailor. It is old. We need a new filter. The filter is close to the mesurements listed by Boland-41. The exact mesurements are 81/2 by 131/4 and...
you can actually make a filter for a lot cheaper,
anyhardware store will carry the filter material on a roll, or bolt, just but the thinnest stuff and cut it to desired size.
many times I have bought Mezlin from a Crafts store, it is very good filter, and has almost the exact permeability as most of your ac filters
hope this helps
Oct 19, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
It should be pretty apparent what comes off the unit. Pop the front cover by the filter and remove any styrofoam, paper and ties that might be there. Also make sure to remove anything that would prevent the coils from breathing properly. Its really simple, dont complicate it anymore than need be and worry yourself, everything that comes out is obvious.
Jun 17, 2009 | Frigidaire FAH085N1T Air Conditioner
My portable
Depending on where you purchased the unit. If you bought it from a mail-house (like the ones out of New York or New Jersey), they have a tendency to break up the manufacture's package and remove the accesories that are supposed to come with it. They sell the DVD player at a reduced price and make a higher profit by reselling the accesories separate. The one I bought (from Macy's) came with the Lithium battery, AC cable, remote, car adapter, AC adapter/charger, and earphones all packed in the box with a carrying handle.
Oct 09, 2008 | Haier Portable DVD Player PDVD7
Removed Styrofoam from A/C
Internal packagings, means in the box-- kits,--brackets--& foam packaging to prevent moving around during shipping or transportations ,and not the unit itself.
Sep 04, 2008 | Heating & Cooling
Need replacement earpads for Sony FM/AM Walkman SRF-H4 headset radio
LIKE YOU ALL, NO CURE OR REPLACEMENT FOR THE ROTTED PADS. WENT TO HOME DEPOT AND BOUGHT ECONOMY PLUS BRAND AIR CONDITIONER FILTER MATERIAL, ABOUT $3.00, FOR A WALL AC. THEN WENT TO DOLLAR GENERAL AND BOUGHT SCUNCI BRAND BLACK HAIR ELASTICS, EIGHT OF THEM FOR $2.00 TO KEEP PONYTAILS, NOW EAR PADS, IN PLACE. CUT THE AC MATERIAL TO FIT, AND ATTACHED WITH HAIR ELASTICS. ONLY A PURIST WOULD COMPLAIN ABOUT LACK OF COLOR MATCH. THERE WAS A SOLUTION, ONLY A MATTER OF FINDING IT. GOOD LUCK ALL OF YOU. R J BURNS, PENSACOLA, FL
Jul 17, 2008 | Audio Players & Recorders
Foam filter fabric
Yes you can buy it in hardware, just cut it to fit in the frame.
Feb 26, 2008 | Friedrich QStar SQ06J10 Air Conditioner
Toshiba A100 Protege
you must change the ac adapter. try to check first your ac adapter then make sure not broken. after you check the ac adapter then you find damage, then you have to replaced with the new one.
Feb 18, 2008 | Computers & Internet
Frigidaire FAH085N1T Air Conditioner Logo
73 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
