SOURCE: Error Code F2E1
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
SOURCE: whirlpool gas range m#SF114pxsq1 diplays an F1 error code
HI. This is a basic Electronic Range Control Board failure code. I would advise to try a hard reset. This may correct the fault, if the damage is not severe. Simply unplug, or shutdown the appropriate circuit breaker for five minutes. After the five minutes have passed, kindly re-introduce power to the unit once more. Try to preform a baking cycle. if the code continues to illuminate during the attempt to operate the range, simply replace the main electronic control board(ERC or Clock).
SOURCE: What needs to be done
F1-E1 Defective ERC...Solution: Replace ERC.
The error E1-F1 indicates that the Electronic Range Control/Clock has been blown.
You can get required parts fromwww.repairclinic.com
NOTE: Some models incorporate the touch pad and the clock as one part.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
SOURCE: Whirlpool range gas model GS445LEMS
I'VE the same problem lower oven don't work and the error is F03. My oven is new (It was included in the kitchen furniture I both from the outlet. What it can be? Maybe wrong installation?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
