SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
SOURCE: Ricoh 3050 printer, Error 990
We got the same error on our machine, so I called Ricoh Direct Tech Support and they said it is a known manufacturer's error. All you have to do is 1. make sure your product is registered, 2. call them up and tell them the error and 3. they will send you a new machine. You will have to send back the old machine in the same box, but they provide the RMA for you to ship it back in.
Good Luck!
SOURCE: have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
