My @ has moved to " and visa versa if that makes sense
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
Go to Control Panel, Regional And Languages support, and make sure you have got the correct settings there.
Your coutnry, etc. Also you can view your current keyboard assignments there.
Try pressing ALT-SHIFT and see if it changes.
Anways, the Regional and Language Settings palel should help you
Posted on Jul 28, 2009
Bobbin tension too loose
You don't give us the make and model of your machine.... so it's hard to give you decent specific advice. Secondly your question isn't making sense. If you are getting loops on the bottom your top tension isn't right(too loose) if your loops are on top your top tension isn't right.(too tight) The only time you would mess with bobbin tension is when you change thread weights significantly. Like from 40 weight to 92 weight or visa versa.
Look at your bobbin case, bobbin carrier, shuttle/carrier..... there is a spring (it's a flat piece of metal) on the spring is a small screw. Use a small screw driver and tighten the spring 1/4 turn. Loosen your top tension a couple turns. (remember right to tight, left to loose)
Mar 19, 2013 | Sewing Machines
Polarity reversed on power seats ...when attempting top move power seats to the forward position..the seat moves backwards and visa versa.
It shouldn't be possible to invert connector plug but what ever you did prior to this situtation is suspect ! Try reversing the plug wiring , It's designed to turn in both directions and will not damage the motor ie back / forward. Good Luck
Apr 11, 2010 | 2003 GMC Yukon
My mouse is plugged in, but is not moving?
There can only be 2 ways. Either receiver button first and then one under mouse or visa versa.
Mar 08, 2010 | HP Wireless Optical Mouse
The cursor doesn't come up on my screen but the joystick does connect. I have reset and reassigned the joystick but still no cursor
Your sensor bar settings may be messed up. Try moving the sensor bar to the opposite position of where it is (if it is underneath the screen, move it above, and visa versa). If this is the problem go to your settings and just change the sensor bar setting to it's correct location.
Dec 14, 2009 | Nintendo Wii Console
Looking for an ofset toilet... do they make them?
yes there is an offset toilet flange that moves the toilet roughly 3 inches
Apr 30, 2009 | Home
I80 printhead will not move from the right position
What you can do is clean the rod on which the printhead moves.  If the problem is not solved check for the data bus cable which helps the printhead to move from left to right and visa versa.  If there is any damage in that data bus better get it replaced by some service centre.
Mar 13, 2009 | Canon i80 InkJet Printer
Up and down of mouse pointer reversed
THE POWER SOURCE IS GETTING LOW AND IT IS TIME TO CHANGE THE BATTERIES
ROD
Mar 05, 2009 | Microsoft Wireless Laser Mouse 5000
Turn signal cancellation
You will have to change the turn sigal switch to correct this.
Sep 06, 2008 | 1998 Nissan Altima
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
