THE FRONT RING
SOURCE: I need to know how to mount a used Millett 15-4x32
If your rifle is taped for scope rings this is a easy thing to do, if you do not have any screw holes on top of the barrel you will have to have a smith drill and tap them out for you. If you try to do this yourself be sure you do not drill to deep. You will need a blind hole tap, most scope mounts are are 6 x 32 treads. You will need scope rings that will let the scope sit on top without letting the bell end touch the barrel, easy if you want sight thru bases. Go get er done! lets get ready to go. It is just in time for a good Thanksgiving Deer roast, than some chili for the week after. Send Pictures.
SOURCE: i have a tasco 4x32 rifle scope and the cross
you dont fix a tasco scope there so cheep you just throw them away,, and buy a new one,,,sorry but thats the way it is with tasco
SOURCE: How do I adjust the reticle for a Simmons Mag 4X32
the reticle should be level if its not you need to turn the scope body round in its mounts till it is level and then nip the scope caps up
SOURCE: I have a Barnett Croossbow 400 purchased at
There is a fix
Do you remember the last thing that happened before your problem started?
