Question about Goodman CLJ30AR32 Air Conditioner
Half of the house is blowing cold air the other half is blowing just air
  • John Rambo May 11, 2010
    damper engaged in no air side
    or
    duct work seperation on no air side. air going into attic or basement.
    or
    worst case: refrigerant flow impeaded in part of cooling coil.
  • Danny Clark
    Danny Clark May 11, 2010
    Do you have two AC units?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sounds like a broken duct off the main plieum.
Posted on Dec 18, 2009
Danny DPA120B1WB portable Air conditioner 12,000 Btu will not produce cool air. The fan will start but no cool air. I tried to reset, restart, and clean filters.
This may sound foolish but it works turn the unplugged air conditioner upside down and leave it that way for about hour and a half , then turn it back over after the hour and a half let sit for half hour plug it in and it should blow cold air , by turning it upside down it allows the oil in compresser to flow
Jul 23, 2016 | Danby Heating & Cooling
The half of my house where the furnace is is hot. So there is hot air coming from the vents. (some of them). Half of the kitchen living room bathroom and 3 bedrooms and the hallway are blowing cold air.
where is the duct work located? In an attic, crawlspace? It sounds as if part of the system is disconnected. Are the outlets at the floor or in the ceiling? Is the duct work insulated? Can you take actual air temperatures at the outlets?
Feb 01, 2015 | Heating & Cooling
Ac is not blowing cold air but holding refridgerant The condenser line is cold at first and blows cold but then get warm
the blend door could be open a bit or half way, meaning it is not closing the hot air. you have hot air and cold air at the same time.
Aug 06, 2013 | Air Conditioning and Heat for...
2004 Toyota Sienna XLE...overheat problem....replaced water pump, thermostat and flushed fluids and added new. Now the temp gage while driving moves up from half on the indicator to 3/4 and the air...
-Are you talking about air conditioning...?
-The fan works but not cold air at all ? that is what you asked?
-If so. then the Freon is very low or no more. Check for leak and fix before refill Freon.
Good luck
Mai
Nov 27, 2017 | 2004 Toyota Sienna
IT BLOWS COLD AIR ON THE PASS.SIDE WHEN THE HEAT IS ON
There is a servo (I don't know what it is technically called, but it functions like a servo on an r/c car) behind the glove box that opens and close valves in the ducts. As the valve is opening or closing it can blow through the stop on the top of the servo over time, and it gives you half and half heat/ac. You can slide the bar on top of the servo to open or close the duct by hand. What I did is left the glove box in with only one face screw. In winter, I remove the glove box and slide a metal bar that connects to the servo over by hand in get heat, and slide it the other way by hand in summer to get ac. Otherwise, it was half and half, and passengers would get rather upset by the fact that while I had heat blowing on me, they had cold air blasting them during the winter. It seemed like a pain to replace it since it has screws almost impossible to get to without a LOT of disassembly.
Sep 02, 2010 | 1999 Cadillac DeVille
The bottom half of the fridge/freezer is cool, but not the top half. What's wrong . This is a side by side.
The evaporator fan inside the freezer usually behind the back panel circulates the cold air and blows it into the fridge. Make sure it's running when the compressor runs. And make sure the fan can blow the air into the fridge through the vent.
Sep 05, 2009 | Refrigerators
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
When airconditioner is on half the vents blow cold air the other half blows hot
The air door actuator on the offending side needs to be replaced.
Mar 28, 2009 | 2002 Pontiac Grand Prix
Heater problems
I had the same problem and changed out the thermostat. The clicking was were the bottom half of the thermostat had actually broken off and was moving in the housing
Jan 22, 2009 | 1998 Ford Explorer
My 1995 pontiac grand am heater is blowing cold air. It will not heat up but thermostat is working
do you have only water in your raditor or is it half and half if you have that it could be your heater core they are none to go
Dec 07, 2008 | 1995 Pontiac Grand Am
Goodman CLJ30AR32 Air Conditioner Logo
46 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
