Question about Ovens
Oven pilot How do you light an oven pilot?
  • boobala Dec 09, 2007
    GE gas stove, probably from 1993 time frame. Just moved in can smell gas when you turn on burner, and can light it with match, but don't know where the pilot is located to ignite all burners.
  • dcwprods Nov 27, 2008
    I am in the middle of baking for Thanksgiving. I realized that the oven was not baking. Turned off the oven and back on. Still no good. Whirlpool closed for the day - any recommendations
  • 213 Answers
Most ovens dont have pilot lights anymore how old is the oven?
Posted on Nov 22, 2007
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Amana oven pilot light
If you have a standing pilot and it is not on, you should be smelling gas in the house.
Try lighting it with a BBq lighter directly.
On some stoves, you will have to press a button and hold that button for some time ..over a minute..while you have the light to the middle of the pilot.
Do not proceed to light the pilot until there is no more smell of gas in the oven.
Oct 24, 2013 | Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Jan 05, 2010 | Magic Chef Ovens
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Ovens Logo
190 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
