Question about Goodman CLQ36AR49 Air Conditioner
How to tell blower speed on Goodman PGB030050 REV A
Need to know how to tell which speed blower is set at by looking at panel behind blower panel door. Also if it is set to medium how to switch to high?
Thanks
  • 86 Answers
One way is to take an amp draw of the motor if you have an ampmeter otherwise
most systems will have the wires color coded black is high
blue is med high
red is med low
yellow is low
and white is nuetral
usually there is connectorson the board labeled "cool" "heat" and "park" park are the unused leads just swap wires
if there is no terminals look to see which wire is wirenutted and switch t with one of the unused ones
Posted on Jul 28, 2009
How to fix goodman furnance A30-15 the blower wont turn on ?
Check capacitor, cheap replacement and easy to do, also spin blower wheel by hand to see if it moves freely. If so could be Cap. U can also try canding blower speeds to see if one of the speeds burnt out. Warranty??
Jun 09, 2014 | Goodman Heating & Cooling
When fan is running- power to fan cuts in & out
Might need an adjustment on the fan limit control. Or the blower speed might need to be set on a lower speed. Temper rise listing will be on the data plate. Check the rise and adjust the blower speed ocordingly.
Jan 09, 2014 | Goodman Heating & Cooling
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
I HAVE A GOODMAN PACKAGED AIR CONDITIONER M/N PCO30-1 B REV. E C/W 9.8 K.W. ELECTRIC HEATER INSTALLED IN A MOBILE HOME. WHAT WOULD YOU RECOMMEND FOR A BLOWER FAN SPEED? CURRENTLY IT IS SET ON HIGH SPEED...
Many have sepaarate speeds for heating and cooling....check it out there should be a heat relay and a cool relay and the motor taps are hooked to each so maybe you can just do a bit of switching wires.....
But, really you probably will have plenty of air flow for the cooling side also if your running that low of a differential on the heating side...
Try it out the worst that can happen is that you will freeze up on the cooling and then you can just switch it back...
heatman101
Jan 23, 2011 | Goodman Heating & Cooling
I just installed a new goodman gcvc90704 today, and it didnt come with a schematic of how to set the dipswitches for the fan control, i went by the one on the door, and when the air conditioner comes on,...
Hello,Make sure the yellow wire from the thermostat is connected to the Y termnal on the blower unit control board for proper cooling speeds.The dip switches can then be set.
Oct 26, 2010 | Goodman Heating & Cooling
I have a Goodman Model GMS80703anaa- For the last 5 days I have had to reset the furnace, now it won't go on at all. The ignitor trips, the thermostat trips, blowers go on, but no flame/heat. When I reset...
They should have said located on a control board.
This is usually located behind the bottom door where
the blower motor is located. It usually is mounted in
front of the blower.
On the back of the door you will take off is a chart
that tells you how many blinks relative to what your
problem may be
Feb 11, 2010 | Heating & Cooling
Need to find the pressure switch on my goodman furnace
It's mounted onto the gas valve. It will be a button or lever that you have to push in or down, depending on the style.
Nov 20, 2009 | Goodman GDS80904BNA Open Flame Heater
Blower speed too fast
The furnace should be a 3 or 4 speed motor in it. On the circuit board there are places maked heat and cool. If you are looking for low the red wire should be plugged into the heat designation. make sure unit is unplugged before changing
Nov 22, 2008 | Goodman GMS80453ANA Open Flame Mid-Size...
Goodman furnace model #GPO 125_4 REV 8 Installed 6/2/2002
Have you measured the temperature in the suppy plenum? Should be 140 to 160 max. If hotter, you have a blockage in the ductwork or vents closed. If within spec, bad circuit board.
Jun 05, 2008 | Goodman GMS90703BXA Heater
Goodman CLQ36AR49 Air Conditioner Logo
174 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
