Question about Intel MicroStar MS-6533 P4 mATX Motherobard w Audio Video LAN - MS-6533 Motherboard
I need to know how much and what type, RAM
I need to know how much and what type, high or low density, RAM this board supports.
    Problem Solver:
  • 15 Answers
The average desktop motherboard has tested support for 4GB of RAM. Look at the RAM in there now, and go to an electronics store. Go to the clerk and say you need this kind of RAM. It should have a little serial code on it somewhere.
You could probably put more than 4GB of ram in w/o anything bad happening.
Posted on Jul 28, 2009
Pc ddr memory what is the difference between high density and low density
you need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Nov 25, 2011 | Computers & Internet
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Problem regarding RAM
youl find out how much mb has the each RAM slot by doing this : right click on my computer (not the shortcut cause that will give you the properties for shortcut) and go to properties. it may be that on properties is total size of rams, if it is find your rams in computer chassis. there will be written the size of each one on each one.
Apr 06, 2010 | Computers & Internet
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Km266-mnb Mother Board .... pc2100 ddr266 ram, will high density ram be compatible? Thanks
By this do you mean you want to increase the RAM on your computer?
I suggest you use PC2100 DDR RAM (same speed) and increase the total RAM to what your require but use the same RAM manufacturer if possible.
If you want to install more than 2Gb of RAM, check the motherboard specification for the maximum RAM that the motherboard can support.
Your motherboards may support more RAM with a BIOS upgrade.
Sep 06, 2009 | Azza Computers & Internet
Does ASUS P4P800 deluxe support high density memories
Here is a link to Asus' Qualified Vendor List of RAM modules for your motherboard. I do not see it mention high density RAM. You would need to search the specs on the modules recommended to be sure.
ASUS QVL
In case you don't have the manual, here is a link for it too:
ASUS P4P800 Deluxe Manual
Memory info begins on Page 2-10. Again, there is no mantion of HD modules.
Mar 01, 2009 | ASUS P4P800 SE (890552603657) Motherboard
How do I determine what kind of memory that I need?
Go to Crucial.com and install their configuration utility through your browser. They will tell you what you have and all the combinations you can do to max out your system. Look at the specs of the RAM and you can get it from Crucial or some other vendor.
Dec 30, 2008 | Computers & Internet
Hello i need to get two things for two new boards i purchased their foxconn648fx7MF-S boards i need the correct type memory in DDR400 (low density) or (High Density) and the correct VGA video card's
Unit Supports up to 2 GB DDR SDRAM , find it on Crucial:
http://www.crucial.com/store/listparts.aspx?model=648FX7MF-S
For the Video board, it depends on how you are going to use the unit and how much you want to spent. GeoForce video boards are great.
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2008 | Computers & Internet
K7vm3 mobo RAM
If you are referring to the ASROCK mobo then it will work on the high density although not as good as with the low density but it will nontheless work.
Oct 13, 2008 | VIA ASRock K7VM3 Socket A/...
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Computers & Internet Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
