Question about Refrigerators
Refrigerator compartment at 60 deg. model maytag MSD2756DE
  • 77 Answers
What is freezer temp????? it should be 0 degrees if not it is probley the defrost elemt on the evaporator. this will need to be defrosted and replaced.
Posted on Jul 28, 2009
Msd2756de fridge side wont cool
all of the above solutions are correct evaporator fan going bad causing the ice to build up defrost timer getting stuck or heating element for defrost not working...good luck
Mar 16, 2014 | Maytag MSD2756G Side by Side Refrigerator
I need to replace a Frididaire Defrost Timer for a 15cuft topmount frig. I bought the timer from Frigidaire with PN#4092799. The guy on the phone at Frigidaire told me that it is behind the control knob...
Hi and welcome to FixYa, I am Kelly.
Actually... You may have bought the incorrect part to repair your refrigerator. The symptom your describing is most often caused by the defrost heater element itself being open. (<-Burned out) The reason I say this is your unit is shutting off.... starting the defrost cycle... but NOT terminating the cycle until the compartment reaches 60 deg F. The fact that it restarts at 60 Deg F is telling you the defrost timer control AND the defrost bi-metal 60 deg F thermostat are both working normally. I would bet if you removed the evaporator coil access panel in the back of the freezer compartment that you would immediately notice the heating element in the glass tube UNDER the evaporator coils has failed or... one of the wires on the end of the heater has failed. It is not difficult to gain access to the evaporator coils. You remove all racks in the freezer compartment and ALL of the screws including the one usually under the light cover and the panel is pulled toward you from the TOP. To remove the light cover there are 2 tabs on one side of the plastic cover that you gently squeeze the cover to release it. The problem can be the defrost timer but... as you described the symptoms; I seriously doubt it.
If in the future you need more assistance PLEASE respond with your MODEL number so we can discuss exact repair procedures applicable to your unit.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Frigidaire Maytag R0131577 215846602...
Entire cooling shut down - restarted 10 hours later, shut down again 12 hours after restarting.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987&diagram_id=28252332#d28252332
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Kelly
Jan 19, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer cuts off and stays off for a long time before it turns back on, all my food in my freezer thawed out and I have to through it all out. My husband thinks it might be the defrost timer or the...
Hi and welcome to FixYa. I am Kelly.
Actually it sounds like the thermostat and the timer are working just fine. What appears to be happening is the timer is starting the defrost cycle but the defrost heater is not working. This will result in a horribly long defrost time until the freezer compartment reaches 60 deg F and the defrost thermostat at that point terminates the defrost cycle.
Defrost element Item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48487&diagram_id=671582#d671582
Detailed view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4070730
Defrost thermostat item 12 above first link
Detailed view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4070255
You should read the resistance of the defrost heater by reading the yellow to blue wire (terminals 2 to 3) on the defrost control when the freezer comparment is below 60 deg F at the evaporator. No resistance = open defrost heating element. This is reading continuity though both the defrost thermostat and the heating element. If you do not get any resistance and you are sure that the freezer is well below 60 deg F then... and only then would the defrost thermostat be suspect.
Defrost control in the overhead of the fresh food compartment is located aft of the lights on the thinner section cand an be manually cycled by rotating the 2 tabs on the face of the timer dial. It will click and stop the compressor and evaportor fan ONCE each turn.
NOTE you must wait 10 to 15 minutes after cycling this so that the compressor will stabilize and restart. Once the comprssor and fan shut off the heater is supposed to turn on and melt the ice on the evaporator until the defrost thermostat reaches 60 deg F and once again provides power to the defrost timer motor to terminate the defrost cycle and restart the compressor.
Defrost timer is item 15 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48487&diagram_id=663054#d663054
Detailed view:
http://www.appliancepartspros.com/part_details.aspx?part_id=4084056
This should be enough information to get you going. I still think that your defrost heater is not working either from failure or a wiring problem.
Kelly
Oct 14, 2010 | Maytag MTF1955GRW Top Freezer Refrigerator
Ice maker is not filling the ice cube maker. model Maytag MSD2756DE
check the water valve on the back bottom of the frig-mike
Jan 09, 2010 | Maytag Refrigerators
The switch on Maytag water and ice dispenser hangs
Need to enquire from the agents if that dispenser switch is available as a spare part. If so, switch off and strip carefully as logic shows you.
Sep 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
Oct 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
