Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator/Freezer not getting cold
I just purchased a used refrigerator (GE side-by-side). It has been plugged in for 3 days now, and the refrigerator is around 65 degrees and the freezer is down to 40 degrees. It was unplugged and sat in a garage for a few weeks. I had to throw out all my food because it all defrosted. Does anyone have any ideas? I don't want to put a lot of money into it since it is 8 years old.
  • bonniej Jul 28, 2009
    We cleaned the coils and all the fans seem to be running. There seems to be airflow also.
  • bonniej Jul 29, 2009
    It wasn't tipped, but I am going to unplug for a few days (couldn't hurt) and see if that helps. I'm almost out of solutions. I appreciate all the suggestions!
    Problem Solver:
  • 7 Answers
Two questions need to be answered. 1) When you moved it, did you tilt it over or lay it down? I did that to a frig. I had and it wouldn't get cold after that. I fixed it by unplugging it and letting it sit for a couple of days. It worked fine after that. I'm just a consumer (not an appliance mechanic) but what I was told that when tilted lubricant flows where it shouldn't be. Then when turned on again it gets pumped everywhere. Unplugging it and waiting a few days lets it settle back to the bottom. 2) If your frig. is now in the garage and there is no climate control (the garage is hot) the frig. won't work as well.
Posted on Jul 29, 2009
    Novelist:
  • 108 Answers
Make sure the condenser coils are clean and the condenser fan is running (the fan is at the back of the machine at the bottom, behind the panel). Could be that while it was being moved around, something got in the way of the blades.
There is also a fan inside the freezer, that you should check. Open the door and close the door switch and listen for a fan. Feel over the vent in the back for air flow. If this fan stops circulating air, the interior coils freeze over, and all the cold air descends to the floor of the freezer.
Posted on Jul 28, 2009
  • StanStihl Jul 28, 2009
    If the fans are running, and the compressor is running (back in the back with the fan) then there are only a couple things left. The compressor could be bad, and only sound like it is compressing, when it no longer really is. The freon could have leaked out. Both off these are pretty expensive and require a pro.
    If the compressor isn't running, the overload/restart breaker could have broken (if you unplug the
    unit, you can pull it off the side of the compressor and see if it
    "rattles" when you shake it). If it rattles, it's a cheap and easy
    replacement. Or the defrost timer (which is probably on the main board) could be stuck and the unit is on defrost. That's somewhat expensive, but still possible to do on your own. Or the compressor could be shot. That is definitely expensive, and you will need a pro.
  • 24 Answers
Is the fan on the condenser coils spinning? (back side of unit behind the bottom access panel.)
If it is not, the heat extracted from the fresh food/freezer compartments is not being sufficiently dissipated.
As a short-term fix, you can aim a box fan (a regular ol' room/window fan) at the condenser coils.
Freezer and refrigerator are not keeping cold
the thermostat controler is most likley bad this is where you set the temp with the knobs you can find the parts online with the model number please rate- jeff
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator GSS22JEMB BB. The defroster heater was replaced. How do I know if the defroster is working properly. Can I manually manually make the fridge go into defrost mode? Also...
To go into defrost manually : Remove the 10"X13" panel from the back of the fridge . You will see a plug with 3 larger wires going to it . Unplug this plug ( UNPLUG THE REFRIGERATOR FIRST ) . The blue receptical will look like this wire#1,wire#2, space , wire#3 . Use an insulated jumper inserted into the receptical to wire #2 and #3 . Plug refrigerator back in . You will be able to see the glow from the defrost heater if the freezer is cold enough and the bimetal is good .
Some models , when the freezer door opens , the fan will keep running and others , the fan will stop , until the door is closed .
There will be a slight stream of cold air at the top of refrigerator section due to the fact , that if it was a larger stream , food would freeze on the top shelf of the refrigerator section .
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer will not get cold
Hi..
You need to check this following:
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
Good luck !!!
Regards
PCmania
Jul 10, 2009 | GE GSS25LGM Side by Side Refrigerator
Ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hghj
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS20DBMB GE side by side refrigerator
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
hope this helped. Good luck
May 20, 2008 | GE GSS25SGMBS Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
631 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
