Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I see a lot of white smoke out of the outlet, what can be the problem i have a 15.5 hp intek ohv motor
  • ProHydroRace May 11, 2010
    If it's the wall outlet there is a fire ....call the fire department!
  • 582 Answers
1) CHECK THE OIL LEVEL IF IT IS OVER FULL REMOVE SOME OIL TO THE FULL MARK
2) IF YOU MOW ON HILL KEEP THE CARB ON THE DOWN SIDE OF THE HILL
3) WORST CASE RINGS OR VALVE SEALS
Posted on Aug 10, 2009
    Champion:
  • 225 Answers
Rings on the piston are shot.
Posted on Jul 30, 2009
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
Oct 01, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
May 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
626 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
