Question about MSI 845 PRO Motherboard
Same error today I also have same problem I remove 2 old 128mb dimm and put 2 512mb pc133...with single ram pc works fine but if I add the second bank ntoskrnl error...
  • genna88 Jul 28, 2009
    they are the same brand & speed..I said that putting one of the new with the 2 older(which are different = 3 difference bank on mobo) it works fine..now it's in this condition..
  • 724 Answers
Are the 2 a matched brand or are they have the same speed
I found that not all memory will work sid by side in seperat banks they have to be compatable with each other and and run at the same speed
Posted on Jul 28, 2009
  • 31 Answers
You have probably put 2 different rams . When you buy 2 sticks make sure you get them from the same supplier and same speed. E.g Kingston and RAM is now cheap.
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Has pc100 128mb and tried to go to Pc133 and wouldn't accept, what is the max memory i can put on this board
the details of that board are sorta sketchy, it could be an intel 810 series or 815 series. theres really no way to tell except by opening it up and looking for the largest exposed ic chip with intel stamped on it, and look for an 810 or 815 designation on that chip.
if its an 810, it may not support pc133 ram, depending on the exact 810 model. if its an 810, it also will not support more than 256 total ram.
if its an 815, it will accept 512 total ram, if not more; however, you will have to go with no more than 4 ram sides- meaning, if you have 2 double-sided ram sticks, you will not be able to add anymore. if you have 2 single sided sticks, and a 3rd ram slot open, you may be able to add a double sided stick in the empty slot for 1+1+2=4 ram sides.
Sep 29, 2010 | Gateway PGA370 E139761 DIMM Motherboard...
Toshiba sp6000 512mb sdr 133mhz chips
These are the memory modules for your notebook, any others won't work. The max is 1024mb
You need these modules:
PC133 512MB (PA3108U-1M51)
PC133 256MB (PA3086U-1M25)
PC133 128MB (PA3085U-1M12)
If the modules you've installed meet the above criteria then make sure they are seated correctly.
Bear in mind it is always possible one of the modules is defective so try them one at a time, also they are non-eec.
Jul 08, 2010 | Toshiba Satellite Pro 6000 Notebook
DELL Optilex GX110 - RAM
Put the "old" RAM back into the computer, to see if the PC will work at all, or if you damaged the motherboard when you were changing the RAM, or if you accidentally disconnected some cables or jumper-blocks.
Feb 03, 2010 | Dell Optiplex GX110 (2909T) Motherboard
RAM error
Populating the memory according to the following guidelines resolves this POST error:
  • DIMMs must be configured in identical pairs.
  • The system will not boot properly if multiple DIMMs of varying density or type are installed in the system.
  • The Entry model servers come with a single 512 MB DIMM. If additional DIMMs are to be added to the existing 512MB DIMM, then another 512 MB DIMM has to be added along with the new pair of DIMMs, or it has to be removed when adding the next pair.
  • Valid DIMM pair combinations use slots 1/5 (Bank A), slots 2/6 (Bank B), slots 3/7 (Bank C), and slots 4/8 (Bank D).
  • Up to 16 GB of memory are supported on the Dual-Core 5000, and 5100 series
  • Up to 32 GB of memory are supported on the Dual-Core 5200 series, Quad-Core 5300, and 5400 series
  • FBDIMMs must be installed in pairs unless operating in single-FBDIMM mode. The server supports single-FBDIMM mode only in FBDIMM slot 1A. FBDIMMs must be installed in sequential order, beginning with bank A.
Jan 27, 2010 | HP Compaq ProLiant ML350 G3 Server
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
New ram problem
try to pull out the old 128MB and let the new 512MB memory, to knew that your windows 2000 working properly.. if the 512MB function then its ok... dont put back again the old one... Maybe that 128MB is not compatible with the new 512MB, is 512MB PC400 or not? and also let your windows restore back to its system working properly and your VGA Card reinstall it again.... hope this might help you, good luck!
Jul 09, 2009 | QDI Group QDI Advance 10B Motherboard
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Presario 700 US
The Compaq Presario 700 US Will only hold a max of 384mb of PC133 RAM. 256mb is the biggest chip you can add.
Jun 20, 2008 | Compaq Presario 700 470024-192 Notebook
MSI 845 PRO Motherboard Logo
77 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
