Question about Nokia N95 Cellular Phone
Cant hear anything through the earpiece on my n95 8gb
If i put it on loudspeaker or use the headphones i can hear all. even after replacing the earpiece the problem is still there. can anyone else help please
Everytime im calling, i cant hear anything in the earpiece, but when i use the headset or loudspeaker then the sounds are clear and working fine
Your speaker has went out. You will need to get a replacement. If you have insurance on the phone, your replacement will be a lot cheaper.
-ex Sprint rep
Jul 15, 2011 | HTC Desire Cell Phone
Tip
C905 - Cant hear, earpiece problem.
This is a little tip for anyone having problems with their Sony Ericsson C905 where they cant hear anything whilst on the phone.
This is only if you cant hear anything through the earpiece, however it works normally when you have it on Loudspeaker...
There is a fault with the C905 ribbon flex, this flex connects to the phones, keypad and then runs under the screen and has pads for the phones earpiece to connect to.
There are 3 methods of solving the problem
1, If your phone is under warranty have an authorised Sony Ericsson service centre repair your phone for you, this is FREE and is the best option.
2, You can buy a replacement ribbon, for these handsets and change it yourself. It looks like the image in the following link
<a href="http://www.findmethatphone.co.uk/fixes/c905flex.jpg" target="_blank">C905 Flex</a>
3, If you are able to solder and feel confident you can try the following fix, you need to make a jumper from the right solder pad to the leg on the transistor just below, use low res wire and be very carefull...
Remember trying 2 or 3 on your handset, if your phone is still under warranty will end up voiding your warranty so only do this if you dont have a warranty...
on May 13, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
When i get a call, and i answer the phone, i cannot hear the person, although they can hear me, i have to put the phone on loudspeaker for me to hear them, which i don't always want to do.
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Sep 02, 2010 | Nokia E71 Smartphone
I couldn't hear the voice of the caller wen sumone calls me... bu i can play music player nd use loud speaker. I use nokia 3110c.
Take care.
Sep 01, 2010 | Nokia 3110 Cellular Phone
I can't hear well when I speak on my phone HTC Snap. The person at the other end can hear me perfectly, but i can hear them very low even that my headphone is set at max. level
Take care.
Aug 12, 2010 | HTC Cell Phones
When i make a call cant hear anything but when i switch to loudspeaker its working can u help
Take care.
Jun 25, 2010 | Cell Phones
The main speaker (receptor) do not work
The problem why you cannot hear the person you are talking to with the one at the top front(the main earpiece) is that the front earpiece of your phone is bad that is you cannot hear anything unless you put it on speaker.
All you need to do is to replace the front earpiece of your phone and you will see that you will hear when you are talking to anyone.
Change the front earpiece as advice and you see that you will hear your conversation when calling or receiving calls.
Take care.
May 09, 2010 | HTC Touch HD Smartphone
Cant hear people on other end of a call
take the phone to local repair shop, earpiece speaker needs replacing
Apr 03, 2010 | Sony Ericsson K610i Cellular Phone
Cannot hear caller's voice
You have told that you can hear well only if you use your headphone or loudspeaker. From this it is obvious that there is no problem with your network but with the earpiece speaker present in your device. So replacing it under warranty is a way to solve this. moreover its only 2 months and so your device still covered under warranty.
Aug 19, 2009 | HTC Touch Diamond Smartphone
Earpiece not working . I can receive a call. they can hear me but I can't hear them
okk. before replacing ur earpiece.. check it with ur headphones. if they u can hear to them and there is no other faut expect the earpiece. u can also check using loudspeaker
Aug 16, 2009 | LG CU400 Cellular Phone
Nokia N95 Cellular Phone Logo
218 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
