CD ROM Drives
Problem for CD ROM Drives
Generic problem for all CD ROM Drives
Cd lector problems
By bambam1 on Nov 22, 2007
my cd drive is not recognize in my lap top compaq presario 2100
Same Problem
Sep 20, 2008
-   My computer is a Gateway m-series, and I've run into the problem where I load up a CD for school and depending on my computer's mood it will either decide to run (often times copping out 2 minutes later by freezing), or refuse to run at all. Often it will not even allow me to open the hatch to retrieve the CD or place it in to try and load it. I've used the pin sized hole to open but the main problem it that it refuses to play at all.
I took my laptop to Best Buy yesterday, after getting nowhere with Gateway's phone "help"desk. The guy that helped me could find nothing wrong, but cleaned my lens with alcohol. That helped and I was able to use the CD drive all last night and for about two hours today when without warning the drive copped out again. I tried the alcohol again; tried restarting; tried crossing my fingers; yes, I even did a little dance with the result that it is now-literally- raining outside. I've gotten nowhere...unless you count that I don't have to water my lawn today...and am at wit's end.
Anybody experience this problem and found a way to fix it? other then buying a $100 extra piece of equipment? -   Guest
Nov 28, 2007
-   Same issue.
I have Presario 2175 running XP SP2.
It started just recently, the CD/DVD drive does not show up on occasion, sometimes it will, then disappears.
I have tried registery cleaners, updated my bios, check my CD-DVD connections, got another CD-DVD drive (from e-bay that was gauarnteed ok), Modifed the registry for lower/upper filters.
When it shows up, I can play CD's for hours, load software fine. When the system goes into a sleep mode it typically will disapper. It is not easy to get it to "re-appear" multiple re-boots, going from hibernate back with something in the drive seems to work.
I have had the system apart, very tedious and checked all connections. When it disppears it will not show up in device manager. I'm somwhat resigned to believe it's a motherboard issue, but why it will work for hours out of the blue is a mystery.
The only time it disappeard while using it was when I was trying to burn a CD RW, then errored out because the device is missing. Still trying to get it back from that ....
The frustation is it can be so many issues, including the OS it makes it hard to know which is the real issue. There are a numbe of scripts that modify the registry, for some reason when I use them "sometimes" it has an effect.
At this point ... I gues I will put up with it .... somday a new laptop is planned....-   gleadbet
Solution #1
posted on Jun 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
buy a new cd rom
Popular Solutions for CD ROM Drives
Questions and Unsolved Problems for CD ROM Drives
Answer
the buttons at the bottom of the monitor come up as osd locked evrytime I try to access them. How do... (More)
Answer
I need to change the coin cell battery in my Dell Latitude 8100, I don't know which panel on the... (More)
Answer
download driver axioom54n
Answer
Screen scrolls constantly in dialog boxes as an example of the problem. It seems like hitting any... (More)
Answer
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CD ROM Drives:
Top CD ROM Drive Experts
Rank: Guru Guru
Solutions: 14900
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD ROM Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
