Question about Minolta Office Equipment & Supplies
MULTIPLE BYPASS DOOR CLIPS - Minolta Office Equipment & Supplies
  • jon4710 Aug 01, 2009
    My door clip has broken I require new one
    thanks
  • Adorjani Laszlo May 11, 2010
    What is your problem?
  • Minolta Master
  • 6,161 Answers
What is wrong with the bypass tray?
Posted on Aug 09, 2009
Must I remove the regulator to replace the clips that attach the cable to the window?
I never have. I pulled the cable from behind the channel and inserted the tabs in the clips , then slipped the clips in place. A bit more difficult, but way less time.
Feb 25, 2016 | Cars & Trucks
Can I put the door hinge pins in upside down I have had to replace these pins multiple times the clip does not hold it for very long
Are you replacing the bushings when you replace the pins? The fit should not be so loose that your pin just falls out.
Jun 17, 2015 | 2001 Chevrolet Chevrolet Blazer
I have a 2003 isuzu rodeo and the rear door button to open the glass window /door got pushed through the door. how do i fix it
Remove the door panel. Panel is attached to the door with clips and screws. Remove screw attached parts such as armrest and other trim. then remove panel clips by using a clip tool so as not to damage the panel. Tool can be found at any auto parts store. After loosening panel carefully remove, wires will be attached. If your switch is in one piece unplug it and insert through hole in panel if it passes right through look for evidence of a retainer. If none is found or if switch is in multiple parts, call dealer parts and ask for new switch. Unplug connector and replace switch.
Jul 09, 2012 | Isuzu Rodeo Cars & Trucks
I just replaced my lamp in my Tv and when I go to turn my tv on it flashes green first then red 3 times.... and I don't get a picture or any sound
there is actually a door sensor on the door to the lamp. if the door is not closed exactly how it was it wont work. is the bulb new and at oem standards? i had similar problem and eventually noticed that the sensor actually came off of the board and was able to bypass door sensor with paper clip and tv came rt on. but wouldnt suggest doing so unless you are electronically inclined.
Aug 17, 2010 | Sony KDS-55A2020 55" Television
Error code c-0960 how can i reset it
C-0960 error code is for the bypass tray on a C350 copier. Make sure there is nothing binding up the tray lift mechanism. To reset open the front door, on the right side where the plastic starts to curve you will find a small hole, in that hole there will be a small button. Use a pen tip or a paper clip to press this button, this will reset the error. If the error returns there may be damage to the bypass lift system.
Apr 12, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Can't get door open
wiring connections or lock latch frozen --to manually bypass latch or to unlock rear hatch -- in the bottom of door panel is a round access hole remove cover just clipped into place using a flashlight and a screw driver about 3 inches in on bottom is the lock latch and window lock latch connections if u pull back on the inner latch u will unlock the hatch which will allow u to open it[ when opened check the wiring connections for corrosion or damage if good ] now u can remove the whole hatch panel and check the latches and actuator the actuator and latches,and rod clips sometimes need to be lubed or sometimes the clips break or disconnect clips can be purchased at any auto store panel is clipped into place carefully pry from a corner and using a screw driver or panel tool pry straight back till panel clip pops replacement of panel put clips in place and push in panel
Feb 08, 2010 | 2005 GMC Envoy
My son has a 96 Land Rover Discovery I that the
You need to start by removing the inner door panel, Remove screws that hold door pull and inside release handle. There are multiple plastic clips that have to be popped out. Use screwdriver but a trim clip removal tool works better.(Lisle tools part #35400). Once panel is loose unhook elecrical connectors to panel, peel back plastic vapour barrier, access to all latch parts, rods window regulator , etc is now available.
Jan 11, 2010 | 1996 Land Rover Discovery
Need to remove the door panel to get at glass
you have to take out the screws on the plastic handle part of the door and then have to disconnect the little plastic connectors behind the panel very carefully ifyou go to the local library they should have a manual that will show you the illustrated location of the connectors and the screw locations
Aug 24, 2009 | 2000 Dodge Grand Caravan
Door switch broke off
no either replace door switch or bypass it ..remove screws at filter opening(if its a top mount filter) pop clips each corner at edge of and lift top switch
Nov 16, 2008 | Whirlpool LER4634J Electric Dryer
23 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
