Question about Car Audio & Video
Radio sound work some times and some times it dont its a factory radio
    Problem Solver:
  • 4 Answers
Could be a number of things. Does it get better or worse when you wiggle the volume knob? Is it FORD? because they have an internal intermittent problem that I believe stems from from the auto sound level (ie: the faster you go the louder it gets) but it can go nuts and just turn up or down at will. If the sound is either on or off it could be something wrong with the internal amp of the head unit, or a bad connection to the speakers on the back of the deck. In closing a guy needs more input to give a direct answer. But the above would be things to check or consider.
Posted on Jul 28, 2009
I just bought a 2006 grand prix and yesturday the radio lights and buttons dont work. The cd wont eject bc buttons dont work and the lights on the radio dont work either u cant see the time ornothing. U...
Hmm sounds like could be that the car was hot jumped from a dead battery or was jumping another car and it may fried the stereo. Should be able get a factory replacement out a junk yard less than $50
Mar 22, 2015 | 2006 Pontiac Grand Prix
2002 Mazda protege LX - Factory radio and after market radios both test good on the bench but dont work when installed in the car. Connectors seem to be OK. Speakers in the car test out good. Occasionally...
one of your speakers is blown and shorting out your deck. disconnect one sspeaker at a time and when it starts working fine you know that's the blown one.
Jan 03, 2014 | 2002 Mazda Protege
No power to my radio
It sounds like you shorted a wire during the installation and the fuse is probably blown.
Jan 01, 2013 | 2003 Dodge Durango
1995 camaro z28 audio problems
Hi Jamie, Here's an old trick which you may find useful. Take a run down flashlight cell and confirm the wiring to the speakers by holding the earthing line of the speaker cable to the negative and flash the positive side with the feed to the speaker one at a time. With each swipe you will hear a thump from each speaker as you connect and disconnect. In that way you can confirm the cables are the ones you are connecting. Color coding is not always the same. Use a voltage test meter to confirm the constant power and ignition power and don't forget to earth the set once all other connections have been made, Withour an earth it won't work, but you know that anyway. Regards John
Dec 14, 2012 | 1995 Chevrolet Camaro
My jvc kd-g820 will not produce any sound and not accept cd
try to find the reset a little indent on the face or hole when you remove the face and push in for 2 to 3 secs with a pen or paper clip. Then try your cd again. Still dont work check to see if you have another cd jammed inside and your trying to put two cds at once.
Ok for your no sound problem. a bad speaker, short speaker (one 1 speaker shorts out all will not work cause the radio is in a protective mode), factory amp needs to be turned on, bose system or amplified system in car needs to be rewired to bypass factory amp), buy special car harness to make factory amp compatible with aftermarket radio, late ford models the back speakers are crisscrossed.
Next time please give car info and type of system you got in it so I could narrow down the possible problems a little bit easier.
Apr 08, 2010 | JVC KD-G820 CD Player
Stolen radio
Sounds like you or the punks that stole your radio crossed a wire and caused a short. Check your fuses
Apr 13, 2009 | 1999 Toyota Corolla
Factory radio with no sound
one of the positive power wires to the speakers is shorting out.alot of times it's the door speaker wires.
Mar 08, 2009 | 2001 Pontiac Grand Am SE
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
