Question about Monster Cable (109611)
Do I have to tear out my wall?
Hello, I did a bad thing. I accidentally pulled the cable out of the metal connector and it broke. I don't know how to get the cable attached to the metal connector. Is there any tool out there that can help fix this so I don't have to rip open the wall and replace the whole thing?
    Problem Solver:
  • 17 Answers
Re: Do I have to tear out my wall?
If I understand you right the metal connector is on the wall connector and the wire is off of it if this is the case take some pliers and take the connector off the wall then take the connector and put it back on the wire just slip it in and squeeze the bottom of the metal connector so it tight on the wire this should help..
Posted on Nov 30, 2007
0 characters
3 Points
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Network Accessories
How to create a network ?? using five computers ? what are the things that i need to know please help me...
for this the hardware you need is CAT 5E cable , rj45 connectors, crimping tool, a 8 port network switch, make straight combination in cat5e cable, then connect one side to the switch and other to the pc do this in all the systems, after that run the network setup wizard thats it
Jul 26, 2011 | Network Accessories
I am trying to connect the ethernet cable to a philips RJ45 wall
There are two standards for ethernet wiring. Most cables use the B standard, but many manufacturers of central wiring boxes (OnQ, LeGrand, SmartHome) have central units wired to the A standard. Wall outlets have to be wired to the same standard as the central unit, assuming there is one. You have to determine whether the other end of whatever you are wiring is wired to the A or B standard. If you are wiring both ends yourself, use the B standard. The wiring diagrams are here:
Sep 21, 2009 | PC Connection RJ45 Connector
Wall connector with cable rj45 wall and computer plug dont give any signal from router to computer. cable AWM E141772 extrending co 20251 60degrees 150V aWG26/8C
Did it work before? Is this a new install? Try replacing the cable with a known to be good one. You may have used a "crossover" cable by accident, in which case it won't work at all. You need a "patch" cable. Sometimes the wires connected inside the wall jack can get loose. Pull the wall jack and inspect the wire connections. Use a small screwdriver to push the wires into the slots if any look loose.
It's possible that the network adapter (NIC) drivers are corrupt. Check "device manager" to re-install the driver. Also, the router may be misconfigured.
Sometimes this problem can be solved by shutting down the computer, then pulling the power cable on the router and let it sit unpowered for a minute or so. Then re- power up the router. Once the lights are green, boot the computer and it should come up.
Jul 15, 2009 | Network Accessories
SCSI Inquiry Command Failure w/Tandberg TDC 4120 tape drive
Try putting the tape drive on the last scsi termination point.
Jan 01, 2009 | Adaptec Cables & Converters...
Network cable
linkserve pvt ltd mali, malidives
Oct 03, 2008 | Farallon Network Accessories
Problem going from jack to switch
can i know what's the length of youre cable ?
Aug 24, 2008 | Leviton (102-5G108-RW5)
Cable box extension
just need some coaxail cable to the right lenth and two f connectors :-)
here is a good cable site i use on a regular basis.
hope this helps
can plz rate my solution
thanks nick
Dec 06, 2007 | Monster Cable DS500-CL-EZ1000 Dataspeed...
Cant disconnet it
all you have to do is unscrew them and then pull them out
Nov 30, 2007 | Monster Cable (109611)
Monster Cable (109611) Logo
69 people viewed this question
Top Monster Cable Network Accessories Experts
Brian Sullivan
Brian Sullivan
Are you a Monster Cable Network Accessory Expert? Answer questions, earn points and help others
