Question about Brother IntelliFAX 4100 Laser Fax
How can set the fax offline - Brother IntelliFAX 4100 Laser Fax
  • Brother Master
  • 6,696 Answers
Keeps telling me it is off line-how can I correct it so I can print
First check on the device and printer under control panel if the status of your printer is offline or ready. If it is offline check your usb cable if properly connected and if ready state then if you send print job set to offline try to reinstall the driver. hopefully it will help you.
May 13, 2015 | Brother Fax-2840 High Speed Mono Laser Fax
Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Jan 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Tip
Printer Offline Error
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
on Jun 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
It states that the printer is offline. i have this machine for my company so how am i able to put it back online?
3. Click on FILE.
7. Try printing.
WINDOWS XP
3. Click on FILE.
7. Try printing.
Jan 13, 2011 | Kyocera Mita KM-5035 Printer
Fax machine is offline
what is a array sensor, i am a brother tech and never heard of an array sensor???????????????
Dec 30, 2008 | Brother IntelliFAX 5750e Laser Fax
The spooler is not connected
3. Click on FILE.
7. Try printing.
WINDOWS XP
3. Click on FILE.
7. Try printing.
pls rate as fixya if helpful! thanks!
Jun 18, 2008 | Computers & Internet
NOT ABLE TO GET PRINTER TO PRINT
If you open up the printer (start => settings => printers and faxes..), and look under the "printer" menu, is "use printer offline" checked? If it is, un-check it.
Feb 17, 2008 | Office Equipment & Supplies
Printer Offline
If your problem still persists then If the printer and the printserver is on and connected to the printserver and the router respectively. Then try right clicking on the printer icon in the printers and faxes window to set it online. Try Printing. If it did not work, then right click on the printer icon again > Properties > Ports > set the proper network port. Apply the settings and try Printing.
Sep 27, 2006 | Lexmark N4000e Print Server
Brother IntelliFAX 4100 Laser Fax Logo
374 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
