Question about GE Refrigerators
Ihave a defrost problem with a GSS22 , heater is ok t stat is ok
How to force a defrost on a gss22
  • 24 Answers
You could turn off the freezer (set the knob to zero/off) and open the freezer door. After about a minute or two, the fan inside the freezer compartment will turn on to help move air over the coils. Depending on the temp inside your house, it may take a few hours. At least that's how my GE side-by-side works.
Make sure you empty the ice bucket (if so equipped) or it will just melt and drip everywhere.
If it ices over on a regular basis, there may be other problems - the defrost element, defrost timer, defrost temp sensor; or the various other temp sensors in the fresh food compartment and freezer compartment.
Posted on Jul 28, 2009
How to test maytag refrigerator defrost thermostat
on your model the thermostat comes with a new heater
http://www.repairclinic.com/PartDetail/Defrost-Heater-Assembly/61006116/1021756
you have to read the t-stat when it's cold,unplug the harness,stick one end into the harness and stick the tip of the other probe into the other wire of the t-stat,or seeing that you have to replace the heater and t-stat anyway cut the two wires going to the t-stat,wire nut them together,manually turn the timer knob to put it into defrost and if the heater comes on you know the t-stat is bad.you can leave the heater on and get a hair dryer,melt out all the ice and then disconnect the t-stat wires and tape them or wirenut them,this way your machine will run for 10 to 12 days before it freezes up again giving you time to order your parts and you won't loose any food.when you get new parts melt out any ice again and change heater and t-stat.most likely the t-stat is bad,common problem.
Aug 27, 2012 | Maytag MSD2456G Side by Side Refrigerator
Whirlpool S21S4D Ice maker stopped working Now fridge stopped working Frezer OK Defrosted ice on condenser and fridge working for time being! Do you think its the mother board?
You have a defrost problem going on. Either the defrost timer, the defrost t-stat or the defrost heater. Remove the back freezer wall and you will see the evaporator coils. This is where the heater and t-stat are located. One of these is more than likely the problem.
Feb 04, 2010 | Refrigerators
Back of freezer ices up .refridgerator warm... Fan is OK..... Top mount freezer
There are 3 things to look for on this. The defrost timer which tells the ref. to go into defrost, the defrost t-stat which sends power from the timer to the heater and then the heater. Most likely out of the 3 it is usually the t-stat located on the evap coils behind the back panel of your freezer section. Easy to get to and easy to change. The stat is the one item that has a wire going to the heater. Hope this helps.
Feb 02, 2010 | Refrigerators
Freezer is only cold not freezing, fridge is cool not cold
You will need to remove the rear panel in the back of the freezer compartment. If Frozen over defrost with a hair dryer. At the bottom you will see a defrost heater WR51X10101 Defrost Heater it has glass around the element inside and will be easy to spot if burned out. Let me know what you find, Sea Breeze
Aug 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
Aug 19, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
QUESTION ABOUT DEFROST TIMER
i'm not sure what kinda timer you have there are two, one is a timer you can cycle yourself on or off the second is a defrost board does the same-thing you just can't force a defrost with it. but the way to know if it working is (defrost timer) cycle the unit in to defrost try to hear any sizzling if so your heater and defrost t-stat are ok i would replace the timer. now on the defrost board since you can't cycle it i would check the defrost element and defrost t-stat with a meter you should read a closed circuit if the heater is good, and if the coil is frosted up you should also read a closed circuit on the t-stat again replace the board. Hope this helps you
Jan 05, 2009 | Refrigerators
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
