Question about Lexmark X7350 All-In-One Printer
Shut off my Lexmark 7300 AIO by way of the power button, now it will not turn on, acts like it is not plugged in...was working fine when I shut it off
  • bpbappraisal Jul 28, 2009
    I had tried all of those remedies and unit still will not power up, is there a fuse or a reset button anywhere?
    President:
  • 3,278 Answers
Try resetting (power off/on) the power surge protector or try plugging your printer directly in the outlet to power on. If not resolved, power off, disconnect and reconnect the printer's power adapter. Let me know if not resolved.
Posted on Jul 28, 2009
  • NinaE Jul 29, 2009
    Unfortunately, there is no fuse or reset button. Be certain that the power adapter
    connection to the printer is snug. If those solutions did not work,
    the printer or power adapter is faulty.
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
My tablet will not turn on after I restarted it.
Just guessing, however, I have found that I need to completely shut down electronics (remove all power sources, including those plugged into power and take a break). I am not sure but generally to actually shut down the power, you need to hold the power up button long enough to actually hear it shutdown.
after a break, begin restoring power to the tablet, the charger, any other related device. It might work.
Jan 28, 2013 | Samsung Galaxy Tab 2 7.0
HP Photosmart C7280 All-in-one has stopped printing. Window just keep saying Shutting Down What next?
Just unplug it, wait a few seconds, then plug it in again. That should fix the problem.
I had the same problem - my Photosmart C7280 AIO displayed "Shutting Down" message all night, and would not respond to any buttons on the control panel, even holding down the Power On/Off button got no response. I was worried about a couple of ink cartridges that it had warned were low before I tried to shut down, so I replaced those.
After looking in the manual and online for troubleshooting help from HP and others, and finding nothing but a suggestion to unplug it (not on an HP site), I finally did unplug it, after first disconnecting the USB cable to prevent any trouble due to interaction with my Mac. Then I aited about 30 seconds, plugged it back in, turned it on, and it started up fine, with no apparent problem.
Jan 13, 2010 | HP Photosmart C7280 Laser Printer
I can't get my HP officejet 6310 All-in-One to turn off
This model takes an extremely long time to shut down.
I have had mine on for 2 years. because it takes way too long to start up and shut down. Still works fine.
If you really really want to power this unit down.
Purchase a strip plug with power buttons for Monitor, CPU, Printer and Device 1 and 2. Shut down the PC normally then hit the Printer button on the strip plug. Viola printer off no worries.
Oct 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Lexmark X7350 All-In-One Printer Logo
152 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
