Question about Janome Mini Compact
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
I JUST BOUGHT MY JANOME MINI SEWING MACHINE. IT'S ALSO MY FIRST SEWING MACHINE.I HAVE JUST USED IT A COUPLE OF TIMES AND THEN THE THREAD SEEMS TO GET TANGLED UP IN THE BOBBIN AREA. THE MACHINE JUST STALLS!!!! I HAVE FOUND THAT THE ENTIRE BOBBIN AREA SEEMS TO SHIFT TO THE RIGHT....CAN SOMEONE HELP ME PLEASE.....
  • 55 Answers
It sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Posted on Jul 28, 2009
Janome sew mini will not fill the bobbin
a part of the bobbin winder is not working and should be checked
Mar 25, 2014 | Janome SEW MINI Mechanical Sewing Machine
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Bobbin case catching thread
I believe that you are talking about the assembly that holds the bobbin case in. The bracket that holds the bobbin case in must be adjusted to allow the upper thread to slide by. Check if the thread will go by this area without "hanging up" while rotating the hand wheel. Also check your bobbin to make sure you have the right one. If it is too high or wide it will definitely be a problem.
Apr 17, 2017 | Janome SEW MINI Mechanical Sewing Machine
Upper thread not engaging bobbin thread...
Hiya Kandie. Usually when you can't pull the bobbin through, the wrong size needle is in, try a different size needle. Hope I was some help for you.
Feb 08, 2012 | Janome SEW MINI Mechanical Sewing Machine
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
This machine came with a very limited Manuel. The bobbin thread is knotting up and not catching as it should. I've re threaded several times removed and reinserted the bobbin, but can't seem to find the...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Janome SEW MINI Mechanical Sewing Machine
Will not pick up underneath thread will not sew
try this
make sure there is a 3-5 inch thread tail on the bobbin
then make sure there is a 3-5 inch on top thread, hold top thread with your fingers( away from the needle) then with your other hand turn the handwheel slowly on the right side of the machine & let the needle down into the bobbin area & see if you can pick up the bobbin thread that way
Sep 27, 2010 | Janome 6019QC Mechanical Sewing Machine
Stepping motor error
There are several possibilities, take a look at earlier solutions page for similar problem Here
I would also suggest a Q-tip or cotton bud dipped in metholated spirit to clean the bobbin case area, especially the recess track where the bobbin case spins.
If there are any needle strikes on your bobbin case which have spoiled the smooth surface required for efficient thread movement over the top, get a replacement for a few dollars.
For the record, Janome gives a 5 year warantee on circuit boards, so in the unlikely event that they fail, free replacement.
Cheers
Bargainbox
Jan 20, 2008 | Janome Memory Craft 9000 Computerized...
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Janome Mini Compact Logo
464 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
