Question about GMC Yukon XL Road Bike
My 2003 H2 hummer transmission is overheating
My H2 hummer transmission is overheating and blowing the transmission fluid all over the right side of the truck. It finally gave us a message '' transmission overheating''
  • GMC Master
  • 4,536 Answers
Better not strain it anymore trannys get destroyed between 200-300degrees check the tran cooler and see what damage is done use jack stands and put the rite fluid in synthetic or reg
Posted on Jul 31, 2009
At what RPM 1st gear should shift on a H2 Hummer 2003
well is that hummer that a 2 ton or 4 ton vehicle ?
would take a lot of revs for first gear to make it roll from a standing start
think it will be fitted with an 6 speed automatic transmission
guessing only from my heavy vehicle driving experiences
first should change below 3000 rpm
if transmission was slipping in first gear you would know
suggestion
ring up the local hummer service division for the correct answer
Oct 12, 2016 | 2003 Hummer H2
Where to you add transmission fluid
If it's a automatic,the fluid goes in the transmission dipstick.Check while running and in park.
Aug 28, 2012 | 2003 Hummer H2
Servicing transmission on hummer h2
Unless you have issues, the fluid is sealed for life.
Aug 14, 2017 | 2003 Hummer H2
Where is the blend door actuator located on 03 Hummer h2. Driver side blows cold, passenger side blows hot
They are not vac on the h2. there is 2 for temp control, one for recirc and one for blend. check the hummer forum as there is a great read for it there. the driver side actuator is really ez as it's under the glovebox, 20 min fix. the rest take removing the whole dash but it's not that tough.
Jan 10, 2012 | 2003 Hummer H2
Hummer H2 2003, shifting problem
Yea, hummers are notoriously unreliable. They are gas gusslers too.
I'm assuming this is an automatic?
When the transmissions computer detects any malfunctions, it will give you a check engine light, or something along those lines.
Do the normal checks such as checking the transmission fluid level as per the user manual.
For further diagnostics you'll need to take it to a mechanic. It's impossible to diagnose a problem like this without driving the car and being able to reproduce the problem.
Aug 09, 2009 | 2003 Hummer H2
2003 Hummer H2 overheats while idling in Park
NED TO HAVE THE CODES FOT THE CHECK ENGINE LIGHT READ.THE CODE WIL LEAD U IN THE CORRECT DIRECTION.GET BACK TO ME W/THE CODE.
May 13, 2009 | 2003 Hummer H2
GMC Yukon XL Road Bike Logo
352 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
