Question about Westinghouse Refrigerators
I have an older Westinghouse fridge. Lights were out and now we can't find the drip tray! The smell is awful
  • 1 more comment
  • Tiffany Jackson Sep 17, 2017
    I have cleaned and bleached the inside of fridge and freezer. The smell is coming from around the fridge itself. I was told to clean drip pan but can't find it. Its an old fridge with no manual
  • richie46 Sep 17, 2017
    Look behind the unit UNDER the refrigerator compartment. It is a tray usually located on top of or around the compressor where the heat evaporates any collected water.
  • Sam Rosa
    Sam Rosa Jan 23, 2018
    depending on make, I found an evaporator tray in the back underneath. that one could not be removed so I cleaned it out with bleach AND cleaned the coils underneath with a vacuum really good! oh yeah, I found a decaying little rodent.after all that SMELL! GOOD LUCK!
    Top Expert:
  • Westinghouse Master
  • 12,962 Answers
Get rid of all that spoiled and put in a bowl of baking soda to absorb smell.
Posted on Sep 17, 2017
5 Suggested Answers
  • 10 Answers
SOURCE: foul odor
Yes ,there is a condensate drain pan in the compressor compartment under your unit.
You should be able to get to it from the rear of the unit, by remove several screws.
Use caution and unplug unit before attempting any repair.
The pan can be cleaned out with warm soapy water.
Posted on Nov 01, 2008
  • 323 Answers
SOURCE: Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Posted on Oct 31, 2009
  • 10865 Answers
SOURCE: Milk which was spilled in the fridge has dripped
Hello. yes. The tray can be slid out. Before you do this, unplug your fridge. Then remove the lower front grill, it just lifts off. Grasp the tray and gently pull it forward. J.
Posted on Jun 22, 2010
clayhendrix
  • 41 Answers
SOURCE: How do I get to the drip tray on a Samsung American fridge freezer? Awful cheesy smell so think it's that...
  1. Consult the owner's manual for the location of the drip tray.
  2. Gently attempt to remove the piece under the doors to see if the drip tray is located there.
  3. Some Samsung refrigerator drip trays are accessible only from the rear.
  4. Reply with the model number for more assistance.
Posted on Dec 16, 2015
Where is the drip tray on the Westinghouse rv432v-l fridge
Not familiar with this model, but these trays are normally underneath, you should be able to access from the back.
Nov 30, 2017 | Westinghouse Refrigerators
Dec 16, 2015 | Samsung Refrigerators
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
MILDEW SMELL FORM THE DRIP TRAY UNDERNEATH. IT IS ONLY 3 MONTHS OLD WHAT CAN I DO,ITS A SIDE BY SIDE WITH ICE AND WATER DISPENSER
Pull the try out and clean with bleach. While you have the Fridge out use a vacuum and clean the coils if they are dusty.
Mar 09, 2011 | Westinghouse Refrigerators
Milk which was spilled in the fridge has dripped into the drip tray behind the fridge and has created the most awful smell. Can the tray be removed for cleaning and if so how?
Yes, usually the tray can be removed for cleaning. You will have to pull the fridge out, unplug power, remove the rear access cover. Then you should see the evaporator / condensate tray and how to remove it.
Jun 22, 2010 | Refrigerators
Ive had my westinghouse moist cold 421 for quite a few years and lately there has been at times water leaking at the inside under the vegetable cripsers . I'm unable to find my user manual but I recall...
The drip tray is all the way at the bottom.Pull of the grill at the bottom of the refrig,tray should be there.
Also there is a hole or tube under your crispers,check that its clear and not clogged with junk.
Jan 20, 2010 | Westinghouse Refrigerators
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Bad smell from vent at back of fridge but able to remove back panel
if you cant remove it then wash it unplug the refrigerator from ac outllet first then remove the carton cover in the back and you gona see the pan were the water is temporaly storege with a garden hose washing the pan and then clean the floor use or news paper around the refrigy is helpfull the water or so in the pan is evaporated with the hot of the compresor sistem that water come frome the freeser compartment....good luck and rate me
Jan 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
2,328 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
