HDTV Can you convert a regular Zenith T.V. to where it will get HDTV reception?
  • niecy1- Dec 01, 2007
    Thank you so much. That is the answernI needed!
    Thank you so much. That is the answer I needed!
  • 99 Answers
No. This tv is not set up for HD. And in no way can it be converted.
Posted on Dec 01, 2007
Where can I download a schematic for a Zenith dtt901 converter
Try the manufacturer's website and/or do a Google search using
" Zenith dtt901 manual pdf
Nov 08, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
If these tv is digital why I need to use a converter box to see the channels
Because it does not have a ATSC nor a Quam tuner in it. Just a regular tuner. As it says HDTV ready. This meant back when you bought it that it will receive HD when a hd cable box is used and connected to the DVI or the Component input in the back. This was a low end set at the time. It will still receive regular cable without a box.
Nov 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
How do I hook up my tv to regular reception using
you will need to buy a digital converter box to get regular tv. The fcc has changes the way you get tv over the air. check at radio shack and they can get the box for you. should be around $40.00.
Jan 29, 2010 | Vizio Televison & Video
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
I installed the zenith Digital converter box lastnight..used an digital amplified indoor antenna..only got 5 channels but today its not recieving signal at all and i bought another indoor antenna thinking...
I understand your issue as not getting the Digital reception from your converter box. The antenna plays an important role in what you can get. If you still have the Amplified antenna try to reduce the amplification and readjust the antenna positions. You might have to do this several times until you get it right. Also, if you live in a city and not a rural location do not use an amplified antenna and see if it is any better.
Good Luck.
Jul 12, 2009 | Zenith Analog to Digital Audio Converter
No HDTV reception with Jensen JE3269 LCD tv
Looking at the manual, the specifications indicate that this is an NTSC TV. You would need an ATSC tuner (a digital converter box) to convert the digital signals into the analog ones that this TV can receive. You may also need an antenna designed for DTV signals to get a good reception.
Nov 11, 2017 | Televison & Video
How to install a converter box on the tv
First Converter boxes are a poor economic investment.
Second you have an HDTV. It does not need a Converter box.
Just connect an amplified antenna.
Built-in ATSC QAM Tuners - QAM and ATSC tuners included to enable the set to receive Digital cable-in-the-clear signals, as well as digital terrestrial broadcasts. HDTV reception is possible by adding an Optional HDTV antenna
Mar 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
Converter box question
This set has the ATSC tuner required for the new over-air standard. No converter is needed.
Mar 04, 2009 | Zenith C27V36 27" TV
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
