Question about Sony Cyber-shot DSC-W50 Digital Camera
Unable to gain access advised to turn camera off and on again with no result
  • 724 Answers
YOu have a memory stick in it?
Posted on Jul 28, 2009
I shot video with an Equinox HD 8 and a Sony FX7 in an indoor swimming pool with lights above it and it was heated. My video came out grainy. It should be crystal clear HD video. Will I have better...
You may already know this but I will give you a bit of background first.
What causes grain in video is called "gain" Essentially it increses the charge on your sensor to allow more light to be recoded.
To eliminate this turn off auto gain on your camera and set your gain to 0db.
Ensure your iris is fully open.
If your exposure in the pool is too dark then you will have to increase your gain. However in my experience when you get into the lake/ocean you will have more than enough light.
the fx7 is a good camera and you are correct it should be crystal clear. Play with your settings out of the pool and get used to how all the setting work.
Hope that helps
Apr 07, 2011 | Equinox HD8X Underwater Video Housing...
It says "turn the camera off, and on again"
You can try to pull and push on the lens as it starts to see if you can "snap" the lens on track again. More than likely that is what has happened as a result of an impact of some sort. Mostly that is what happened. Be advised that you could damage the camera even more, but it may be worth a try since it is not working anyway.
Jan 21, 2010 | Panasonic DMC-TZ4 Digital Camera
Cant gain access to the management URL for wireless router
you can do all over again...look for the reset button (hole) at the back. You might need a paper clip or a pointed one to push it. Hold it for about ten seconds and it resets to factory default.
Aug 16, 2009 | Computers & Internet
Wireless Network Setup
Install the Cisco Clean Access Agent software on your laptop. Contact your server administrator for the appropriate download for your operating system.
The software must be present to scan your system and send information to the Cisco Network Access Control device.
Feb 06, 2009 | Belkin (F5D7230-4) Router (587009)
Unable to see pictures on my sony dsc t70 memory card
Try connecting MS directly to the PC (Via an adapter, if necessary)
Jan 21, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Sony Cybershot 10.1 DSC-N2
throw it at the nearest person while yelling JAPAN FOUR!!!! this works everytime i try it
Oct 01, 2008 | Sony Cybershot S650 Digital Camera
DSC S600 Won't stay on
i know this will sound really obvious, but i had the same problem a while back and changing the batteries fixed it
it might help
Jul 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
DSC N2 :The switch off switch on and "Accessing" message with the beeping was so annoying. As the lens came out, I held it in place and turned the camera off, I could feel the motoor pulling (three times ) and gently resisted the retraction. the camera turned off with the lens out. When I turned it on the problem was resolved (hopefully permanently). €z
Dec 21, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber Shot DSC-L1 Digital Camera
Sounds like a jammed lens block assy.Does lens make any attempt to open??.Did camera get a knock or fall.Not much you can do but send for repair,Would advise get estimate before proceeding with repair.,
May 20, 2007 | Sony Cyber-Shot DSC-L1 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
