Question about Bosch Exxcel WFO 2264 Front Load Washer
I cannot unscrew the cap next to the draining hose situated bottom right hand corner in the base behind clip on cover.
    President:
  • 1,273 Answers
It IS difficult. Try something to give you greater leverage. I use channel locks, and grab the middle part of he cover. There's an "O" ring behind the cap. When you do get i off, spray the threads and "O" ring with some silicone spray.
Best Regards, --W/D-- Please feel free to rate this solution!
Posted on Jul 28, 2009
Changng antifreeze on a kia sedona
there is no drain plug you will have to take the hose off the bottom to drain it then turn the engine over for just a few seconds then turn it off , this will pump out any other fluid
Oct 26, 2008 | 2002 Kia Sedona
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
How do you open front panel on miele w864 to clean out drain pipe to uper right hand side of drum i belive this has a sensor that detects when blocked and once clear machine will work ok , drain pump is...
Hi - in most cases there are three screws behind the door, 2 screws for the door lock, some models will require the removal of soap dish and screws.
Should not be the case here, 2 screws on the lower part of the front panel, open the small trap door bottom RH corner unscrew cap to remove the rubbish from the drain pump as this shuts off the machine too.
Be careful to have a contaner to catch H2O as the cap unscrews.
May 28, 2011 | Miele W864 Front Load Washer
My washer won,t drain how hard is it to replace the pump on a lg wm2016cw
Open the little door in the bottom left hand corner, unscrew the black cap and drain the water out.
If this doesn't fix the problem, you may need a new Drain pump. Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new drain pump and reassemble.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | LG WM2016C
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
I don't know where the filter is in my siemens washing machine to clean it. I think this is causing the problem I''m having as the washing powder is sticking to the clothes. Can you help please.
Check the filter at the front of the machine at the base.
There should be a small cover at front of machine at base.
Open this cover and inside you will see a circular cap.
This needs to be unscrewed anti clock wise, it can be stiff if not used before.
remember you will have to catch the water that comes out and pull out any debris inside.
It is possibly blocked or has debris inside.
Remember you will have to catch the water be prepared.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Siemens Washing Machines
Water won't drain. the washer has worked fine for 7 years
Sounds like your lid switch is broken. This is located under the top of the washer and is activated by a tab that hangs off the side of the lid.
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the front bottom corners (may be behind the end-cap covers), or rear bottom corners, pull panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the lid switch that is screwed to the underside.
Good luck to you on this!
Jul 03, 2010 | Kenmore 22422 Top Load Washer
How do i clean the pump on my whirlpoll awo 3551
Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Jan 25, 2018 | Washing Machines
Bosch Exxcel WFO 2264 Front Load Washer Logo
214 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
