Motorola's have had alot of problems my phone the same exact one did that too and they have dis-continued motorola for these reasons you will have to get a new phone or suffer with the problem.
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
hello there....well its quite simple...to unlock the phone to any network you need to call the customer care of your original network provider( AT&T) ....just keep the model number of your phone number handy (you will find that on the box in which you got the phone)...or the IMEI number (15 digits mostly) by dialing *#06# on your phone or beneath the battery or on the box near bar code....this is a paid service and charges differ from network to network
that should solve the problem.....you will be able to use any sim in your phone of any service around the world
you dont really have to redo the numbers again..you could just replace the speed dial you want with the speed dial number but if you still want that number just jot the current speed dial number down and then replace it with the one you want and do this for any other numbers you'd want to change..its simple really :)
under tools there is a record option. erase all things that have been recorded. the button on the top screen on the right hand side allows you to record phone calls. You have probably been hitting it on accident and recording calls and such. Let me know if this works.
while pressing a number in dialing dont press it continuosly for more than 3 to 4 seconds otherwise it takes number as turbo dialing number. In setup(in the dialing menu where numbers are displayed) there is facility of turbo dialing i.e. speed up dialing such that you provide phone numbers numbers between 1 to 9 for example in 1st number you provide number of your dad then when you press 1 continuously then your dad's number gets called. So, as you have not set your turbo dialing this message has appeared.
i want to of fixed dialing in my motorola A1200
