Question about Sony Playstation 3 (PS3) Console
Ps3 help i need help again i need to know a subnet code a gateway and a defalt router code and if you get a chance i can you send me a video of someone seting up internet connection wireless but make sure they dont hide the wep key
    Problem Solver:
  • 18 Answers
Make sure they dont hide the wep key? Every one has a different one so it will not work for you. It should be on the back or bottom of your own modem/router. Sometimes it will be called a wireless key.
Posted on Jul 28, 2009
  • 59 Answers
The wep key is indiginous to your internal security... you need help in basic networking.... You need to setup your wireless router :
Your router will have a default IP
usually something like 192.168.1.1
This will be your "Default Gateway"
Your subnet is usually 255.255.255.0 by default on home routers.
You will need to open your web browser and login to your router to set your wireless encryption(password). Refer to your wireless router documentation and quick start card. If you are uncomfortable doing any of this I suggest you hire a trained professional.
I hope this helps.
Subnet mask
subnet mask is usually 255.255.255.000, or something like that. If you not know what it is, no use trying to set it up. Most devices do set this up after they know what the ip address is. Look what the router or your hub makes for other devices. The gateway (address) is the ip address your provider gave you to connect to.
Jul 15, 2014 | Microsoft Xbox Video Game Consoles & Games
How do you get your IP Address, Subnet Mask, and your Gateway codes
Connect your computer wired or wirelessly to your router.
in windows based comp
open command prompt
type -- ipcofig
you will get your answer
Jun 10, 2014 | Linksys -Cisco Wireless-G VPN Broadband...
On ps3 coming up as dns error
The settings on the ps3 are wrong by the sound of it. You should have the dns set as the address for your router, that in turn should use the dns from your isp.
so say you router is 192.168.1.1
then your ps3 settings should be something like:
ip address: 192.168.1.2
gateway: 192.168.1.1
dns: 192.168.1.1
subnet mask: 255.255.255.0
Replace 192.168.1.1 with your routers actual IP address.
The ip address can be any unused address from 192.168.1.1 to 192.168.1.254, unless you've restricted the address range,.
Gateway just means your router.
Subnet mask tells the computer what network to send data on, always the same unless you're using more than one network connected together.
Hope this helped.
Nov 26, 2010 | Computers & Internet
Error code 8002ad23
Hi Giles
You probably have your router connected to your modem, and a PC connected wired/wireless, and the ps3 connected wired/wireless.
1. First you need to start your ps3 system. Go to your network settings and select information. Write down your IP, Subnet mask, Standard Gateway, and the primary DNS.
2. Start your PC and go to your networks settings. Right click your network adapter, click properties. Select "Internet Protocol version 4 (TCP/IPv4). Click properties and type in manually the IP adress, Subnet mask, Standard gateway and DNS.
Then you click "Advanced" and then you click "WINS" then "Activate NetBIOS over TCP/IP". Save your settings and connect the ps3 to your network (should not make a difference if you do it wired or wirelessly)
Let me know if this helped and please do rate my solution.
Regards
KreativeGeek
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
HELP MEEEEEEEEEEEEEEEEE
192.168.0.1 or http://192.168.0.1/index.php
this is your modems default web page
default username is admin/Admin
default password is password/Password
this should work for all routers if this dose not work put your routers ip in the top bar no www. needed
Jul 07, 2008 | Sony Playstation 3 (PS3) Console
Ps3 keeps on saying ip timed out
your ip settings are most likely wrong, check your desktop pc settings
here is how
start -> run -> cmd -> ipconfig
note, ipaddress, subnet, gateway
if your desktops ip is similiar to 192.168.1. 2 to 254
then set your ps3's ip as 192.168.1.25 for example
just a number between 2 and 254 (the 1 is used by router) witch isnt used.
your address might show 10.0.1.20 for example or a more complex ip like 86.32.55.100 if this is the case set the ps3 on automatically get ipaddress and dns server.
if you need any help let me know. Good luck.
Apr 02, 2008 | Sony Playstation 3 (PS3) Console
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
PS3 access problems to media server on wrt350n
I believe a simple solution to this beings with assigning a static IP address to the PS3
IF your router is 192.168.1.1 and
your subnet mask is 255.255.255.0
and your DHCP range is 192.168.1.100 for
50 licenses to 192.168.149
The address your PS3 between 192.168.1.2 and 192.168.1.99
Configure you PS3
IP address192.168.1.3
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.1
DNS Address 192.168.1.1
(for the above DNS address to work you must have loaded the ISP assigned IP addresses into the router which you probably have alrready done.
Let me know if this does not work. I will respond to messages here until we resolve the issue.
Then on you router your DMZ address should be set to 192.168.1.3 (your PS3's IP Address)
Dec 24, 2007 | Linksys WRT350N Wireless Router
Internet fails from dns
To access the internet from a home broadband network you need the router appropriately configured on the WAN or internet service provider (ISP) side and the attached computer to have an appropriate IP Address, Subnet Mask, Default Gateway and DNS addresses assigned to the network adapter.
Based solely on the title you should understand the following the belief here is that the PS3 is missing DNS address(es).
DNS address(es) are IP address(es) for servers that convert names like www.fixya.com into IP addresses to send messages to normally.
Your ISP generally assigns DNS addresses for your use.
How do DNS addresses get into the computer's network adapter configuration where they are needed? There are two ways generally in home networks someone manually puts them into the computer or someone enters them into the router and via a service called DHCP they get placed in computer's network adapters configured to accept information from the DHCP service on the router.
If the heading of this problem is correct the PS3 appears to be complaining because the DNS address(es) have not been configured into the computer or the router by the user as expected by the PS3's network adapter. I have no PS3 experience however I believe this information may help to resolve your issue.
I hope this helps
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
