Question about The Computers & Internet
Increase the sound of turn signal volume. - The Computers & Internet
  • The Master
  • 4,780 Answers
There have been a number of cars where the manufacturer responded to complaints of silent turn signals by fitting various devices to produce more noise including a tone through the audio system.
Various aftermarket suppliers also produced such a device.
I fitted an old noisy relay to my friend's car to overcome the problem because he preferred to hear the traditional ticking sound A small loudspeaker and a suitable series resistor would perform the function but a piezo buzzer is probably the best solution, connected between the flasher unit or switch and ground.
Posted on Sep 17, 2017
When i first turn on tv sound is fine . then it will drop down in volume badly .
Many newer types of TVs have what's called "Volume Leveling", which means the TV automatically lowers the volume if a sudden increase in the broadcast signal volume is detected. Check to see If "Volume Leveling" is present on your TV and currently turned "on". Refer to your owners manual for this. It should be in the Audio section in the menu on your TV. Turn the "Volume Leveling" to the "off" position to disable "Volume Leveling".
Jan 23, 2016 | Televison & Video
How can i get rid of jarring sound from my intex 4.1 hometheatre? the jarring sound peaks when i increase bass/main volume levels
You are approaching the cutoff level and getting distortion.
You you have too much amplification or too strong of input signal.
You can can turn down compression or turn up attenuation on the receiver and check other Dolby or neo settings from your manual. Or, don't turn it so loud.
May 08, 2014 | Audio Players & Recorders
Samsung le32r7 volume wont turn up anymore
Are you using a box of some sort for signal with this set?
Dec 18, 2012 | Samsung LE32R73BD 32 in. HD-Ready LCD...
How do i turn my sound up
The Windows operating system on your Toshiba laptop contains a functionality that allows you to increase the volume.
Your laptop's volume is a measure of the decibel levels of sound that your Toshiba laptop will put out.
If you are having trouble hearing music of video files, you may need to boost the sound volume, which can be accomplished by following several steps.
Press the "Start" button on your desktop.
Click on the "Control Panel" icon then double-click on the icon labeled "Sounds and Audio Devices."
Click on the "Volume" tab then move the device volume slider to increase the volume.
Close the "Control Panel" when you have completed the operation, and your volume should be louder.
Hope this helps.
Nov 20, 2012 | Toshiba Computers & Internet
Cannot increase the volume on Coby TV
Your tv is on 100 but it sounds like its only on 50. There is a solution is go to the menu then go to sound and then turn balAnce all the way down
Jul 02, 2012 | Coby 40 TFTV4028 LCD TV
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
How to increase my nokia n70's internet connection & how to increase my headset's volume?
you may want to try this:
#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
for the headset volume, if your headset is the type that has volume controls or, check the side panel of your phone, try pressing arrow up to increase volume, arrow down to decrease, or go to the settings of your phone, look for headphones then volume
Apr 14, 2011 | Nokia N70 Cellular Phone
I want to increase its speaker sound and ear piece sound but i dont know how to
Volume keys: These keys allows you to turn up or down the volume of the ringtone and the speaker. Press these keys to turn the volume display on, and to change the volume.
To lower the volume of the ringer during an incoming call, press the down volume key to the desired volume, or until the option changes to Vibration All Activated. The volume keys can also be used to scroll up or down to navigate through the different menu options. These keys are also
used when the Music Player is active. While on call turn on the speaker and increase the volume with the Volume Key.
Jan 16, 2011 | Samsung Cell Phones
How to increase the sound
To increase the sound of your motorola MOTOZINE ZN5 cell phone.
You can increase the sound of your phone in three categories.
1. music volume,
2. ringer volume,
3. keypad tone volume.
To increase the music volume, you go to the multimedia, select sounds, once the song is playing then you click on the up button that is by the side of the phone. You can increase it to the volume that pleases you.
Further means to increase the volume of your phone is that you go to the 'menu', click on the 'settings', select the 'profile', select 'personalize', a page will show up with a list of data that can be changed on the profile, select the ringer volume, keypad tone or whatever sound you want to increase and increase it with the direction button pointing upward that is by the side of the phone.
To increase the keypad tone, from the home page, click on the up button that is by the right side of the phone, the volume of the phone will increase.
Take care
Jun 25, 2010 | Motorola Mobility MOTOZINE ZN5 Cell Phone
Computers & Internet Logo
2,287 people viewed this question
Top The Computers & Internet Experts
Fred Steinberg
Fred Steinberg
Level 1 Expert
Ed Watson
Level 1 Expert
Alexey Krenvalk
Alexey Krenvalk
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
