Question about Cameras
On/Off button stuck,how to get it out?
When i turned my camera off the on/off button stuck in an now i can't turn it on again, if there any way to fix it or to get the button unstuck?
  • 724 Answers
If you can get to the inters of the button movement a small pri may relese it usint the point of an exacto tool
Posted on Jul 28, 2009
When I turn camera on it says to remove lens cap and press button, It seems like the lens is stuck?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Mar 19, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
How to fix my DSC-W70..it always say turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Nov 13, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
My lens is stuck in everything eles is fine
Please try initializing the Camera to resolve the issue.
First, please press the HOME button on the Camera to display the home screen on the LCD screen of the Camera.
Then, select the "Settings" option and then select the "Main Settings" option on the Camera.
Now, select the "Main Settings 1" and select the "Initialize" option and press the middle of the control button to initialize the Camera.
Then, select "OK" and press the middle of the control button to initialize the Camera. If the issue still persists, it is required to service the Camera.
Nov 24, 2009 | Sony Cameras
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Camera is stuck in voice record mode when I turn the camera on and I cant change it to camera mode
I have the same problem - mine is from using the camera in the pit at a concert - I think the camera got wet to some degree. I have found a way to get to picture capture mode, but it is a workaround and not a fix.
If you hold the display button (>) in for a couple of seconds, and then turn the camera on, it will go into playback mode without the lens extending. From there, if you press display button (>) again, it will go into picture capture mode.
I'm still hoping that there is some way to fix this, but haven't found one yet.
Jun 24, 2009 | Pentax Optio S5z Digital Camera
My camera lens on my cyber shot wont open
dont ask here, con men at large!! they will take your money, and give no you answer :(
Mar 17, 2009 | Sony Cyber-Shot DSC-S85 Digital Camera
Power Button is stuck down
sir,this is common for this model. internal micro switch conecting lever is broken u replace
Jan 03, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Aug 20, 2007 | Pentax Optio M20 Digital Camera
Off and On
The power button must be stuck. Try to clean it.
Jul 02, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
