Question about Nintendo Wii Console
Playing the Wii, I see some dark, sometimes green
Playing the Wii, I see some dark spots ,black or greenish areas on my TV. When I change the input to a blue screen and still see those areas dark or green. after a few minuets they disappear. I noticed this happening when I use the Wifi, for example, using the Internet Channel, Wii shop or a game that has online play
Has anyone experienced this problem themselves?
I already got the GPU replaced as well as the reader and it solved the problem happening all the time but as I stated above I see it more during the Wifi actions. My Wii sits on a shelf above my TV stand, I tried moving the Wii as far away as I can and tested the Wifi and still had the same problem ( I think)
Any advice? could it be my CRT Tv? (27" RCA trueflat) is going up? could it be the WiFi built into the Wii?
Thanks all
  • 53 Answers
Nothings wrong with your wii it the tv the screen was probly left on and thats what happens
Posted on Sep 23, 2009
The dark areas of a picture is red
the screen itself is going bad and wearing out . there is no repair except replacement of the tv .
the screens are so expensive to buy there would be no point
sorry i could not bring you better news
Feb 02, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
When i turn my Wii on it does not show up on my screen all the time. Sometimes it does but not always. It usually shows up as a black screen. Everything else on the Wii works and I can eject disks and its...
try changing to a different input on the tv, or a different tv if you can(if you haven't tried that yet). if it stops then you know it's not the game but maybe the tv or the input. they do wear out from things connecting and disconnecting. you could also try a new cable from the wii to the tv. unplug the cables and check the length of the cable carefully to check for cuts or exposed wires (pets can chew them ect...). if you find anything odd, replace the cable right away. if you have ever had you wii modded in any way, that could also be the problem. even if it was a while ago.
hope this helps
Apr 17, 2011 | Nintendo Wii Console
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
My TV works fine. The only problem is that when i'm watching a movie, or playing PS3 the field seems dark. Sometimes is FIFA Soccer, in the shadow, i can't even see my players because of the dark...
It is possible that there is a allergy that is growing the blue and green gun, it will not grow in the red gun, and it blocks the video and makes it look dark, on the greenish side. To fix the problem, you have to change the coolant in the guns, and then it will look like new again.
Jan 25, 2011 | Toshiba 46H84 46" Rear Projection...
Wii is suddenly only playing in black & white. I've unplugged and replugged at wii and at TV, but not worked - any ideas?
From the Wii, the Audio-Video (AV) cable is Red White and Yellow. Now, those R, W, Y should connect to the R, W, Y inputs of your TV. At times, the inputs to the TV have a Red, Blue, Green input - DO NOT USE those inputs. This is precisely what happened in my case. Now, it is fixed.
Dec 02, 2009 | Nintendo Wii Console
I need to know how to hook up a nintendo wii to my sony fwd-42pv1 plasma. I also have a problem with green pixels in dark areas of my picture
This is pretty easy. Just buy the cables that have S-Video connection. Then plug the wii into the S-Video in on the left side of the monitor. Plug the Audio cables to your reciever or speaker in port on your sound system. Or, the other option is to Find or get a BNC to RCA adapter and use the RCA cable that came with the wii. My TV came with the BNC to RCA Adapter. The BNC location is on the left side of the tv, just above the S-Video connection. Then just change the input selector till you get the right input.
Dec 27, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Jul 01, 2008 | Sony KV-32FV27 32" TV
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
Aug 16, 2007 | Nintendo Wii Console
TV has a greenish tint
first off are there any speakers close to the tv ?. if so move them secondly your degauss circuit may need servicing.
Jun 04, 2006 | RCA 20F530T 20" TV
Nintendo Wii Console Logo
144 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
