Focus dial shorting to the chassis.
I have a Quasar Model WP4210NW television from 1976, serial number AD6344. A few weeks ago it started making an ominous hissing sound, and I was terrified that the CRT had started leaking (terrified because it's the oldest one I own and I got it from my great-grandparents). Strangely it only hissed when it was on. So I took the back cover off, turned the tv on, and tried to pinpoint where the hissing was coming from. It wasn't the CRT leaking, but it's the Focus dial. When on, it seems to be shorting to the chassis. A beam of blue electricity shot out in the same spot in a constant manner. Meaning its always on. I loosened the screws holding the dial on, then re-tightened trying to loosen any dirt that may have gotten under them, but it only seemed to make it worse. Now there are multiple beams of blue electricity, and some of them move around a bit, occasionally creating very breif sparks.
Is it improperly grounded or the focus dial's insides shot? Is it repairable, or must I replace the component?
    Problem Solver:
  • 3 Answers
My friend it seems like it's about time for this set to retire there is a high voltage in a low-voltage flyback or line output transformer even if the TV is off and unplugged they can kill you if you have a voltage leak and you really want to keep this TV I would take it to a professional television repair shop they will have all the tools necessary to diagnose properly so please be careful when inside a CRT television good luck in your effort to repair the set
Posted on Aug 01, 2009
Weight quasar model sp2722
Click here to download the manual to this TV. It will have the detail you want.
Nov 29, 2012 | Quasar SP-2722 27" TV
Need to know part number for rear brakes of ford focus 1.6 16 valve model 2003
go to your parts shop with the users manual and the chassis serial number and they can find the original part first and the the immitation if you want!
May 21, 2010 | 2003 Ford Focus
Codef1
This is a known problem with this model. Call 800-847-9083 and give them the model and serial number to see if your unit is covered by a recall on the control board. I called a few weeks ago and they sent the part and a tech to install it for free on my 3 year old machine.
Apr 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Rca rear projection broke?
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
Apr 02, 2009 | RCA P52921 52" Rear Projection Television
Television set wont turn on .
labor and parts are around 200.00 us dollars.
Dec 23, 2007 | RCA P52960 52" Rear Projection Television
Quasar focus
To find this information You can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the camcorder. Tell them that you need a copy of the owners manual and that you are having problems with distorted video recording. They will be able to help you find a solution. I Hope this information helps you with your camcorder problem.
Nov 29, 2007 | Quasar VM-L450 Camcorder
Vv 1220 screen shakes
Probable bad electrolytic capacitor in vertical circuit.....T.
To get more help from different experts, list your tv in the correct catogory....
All products>Quasar>VV-1220 Standard Television>
Oct 24, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
