Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Just recently replaced lamp cartridge &
Just recently replaced lamp cartridge & when the set is turned on, green horizonal lines appear for approx 2 min
trying to figure out why.
  • 64 Answers
Did you touch the lamp? or Lenses just outside the lamp? Is the lamp the correct one? If so...clean carefully and fully (using soft cloth and just water...the cloth should only be slight damp...not wet)
Posted on Aug 01, 2009
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Thin horizon green lines on my tv from one corner to the next, the line appear when tv is turned on
if your TV is a standard CRT TV the problem is on the vertical section of the mainboard .you need to replace all the small capacitors on the vertical IC section .replace it with the same rating and value.vertical IOC is found just near the The plyback transformer..
Jul 27, 2011 | Televison & Video
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
