Say that it is connected but will not print test sheet
  • efs_perpends
    efs_perpends May 11, 2010
    What printer? What OS?
    Scholar:
  • 110 Answers
The issue could be with an improper installation of the the printer. Uninstall the printer drivers and software and then restart the computer with the prnter disconnected. Reinstalling the drivers after this would be the easiest way to get it fixed. Is still unresolved please let me know.
Rate if useful.
Posted on Jul 28, 2009
HOW CAN I PRINT A TEST PAGE FOR MY KODAK ESP 5250
To print a test page:
  1. Make sure you have the latest version of firmware
2. Load8.5 x 11-in. plain inkjet paper in the paper tray. 3. Dothe following steps depending on the printer: ON ESP 3250, 5250, Office 6150 or 7250:
  1. On the control panel press Home.
  2. Select Maintenance, then press OK.
  3. Select Print Test Page, then press OK.
  4. Press Start.
  5. Wait for the test page to print.
For the 5000 Series Printers, a diagnostic sheet is usedinstead of a test page. To print a diagnostic sheet:
  1. Make sure you have the latest version of firmware. See How do I upgrade my all-in-one printer with the latest version of firmware?
  2. Load 8.5 x 11-in. plain inkjet paper in the paper tray.
  3. Do the following steps depending on the printer:
ON 5100: 1. Press and hold Quantity + Copy. ON 5300 or 5500: 1. Press the Menu button. 2. Scroll down to PrintDiagnostic Sheet. 3. Press OK. 4. Press Start. Wait for the test page to print.
Nov 20, 2010 | Kodak Office Equipment & Supplies
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
Problem in color printing
I suggest making sure you installed them correctly, you can take them out and put them back in, it will ask you if you just replaced the cartridges one by one "select yes" if they are new, then try to print out a test sheet (which you do this through one of the options in your "menu" on the machine itself, it should be in your manual or you can look online in the Brother 240-MFC troubleshooting tips for printing, this just happened to me a few days ago and I got the answer there. So, when you print out the test sheet it will probably have colors missing and you say "NO' that it is NOT GOOD, and then it will do another cleaning and then print out another test sheet and hopefully it will work then, otherwise tell it NO again and have it do another cleaning, sometimes it does take a few times. This happened to me the other day when I replaced a black ink cartridge and I could not get ANYTHING TO PRINT, it kept coming out BLANK PAGES, so I went to the troubleshooting tips on the website and this was the advice I was given, it took THREE CLEANINGS and three test sheets before the black boxes printed out fully on the test sheet with none missing and ONLY THEN was I able to print successfully, GOOD LUCK TO YOU.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
My copy prints come out blurry after changing ink cartiges
Try this:
Checking the print quality:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
  4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
  5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
  6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
    If you can see missing short lines, press 2 (NO) and go to Step 7.
  7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
  8. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
  9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
  10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
Setting the Alignment:
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
    If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
    Thanks, Joe
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
  1. Press the Menu/Set key.
  2. Press the up or down navigation key until TEST PRINT appears on the LCD.
  3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
  4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
StepA - Checking the print quality:
  1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
    Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
  2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
  3. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
  4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
  5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
StepB - Setting the Alignment:
  1. The display will then read "IS STEP "B" OK?".
  2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
  3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
  4. Press Stop/Exit.
Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
