Question about Motorola Mobility RAZR V3
No display My Motorola V3 has no display. The keypad lights and it recieves calls and you can still cal out, if you know the phone number
I need to master reset my Motorola v3. I don't know the code to put in.
Here are a few of the most used Tech Codes for the v3
1998072 - To unlock almost all Motorola mobile phone
*#06# - Displays the IMEI number of your phone
*#403# - Displays the manufacturing details of your mobile phone
*#301# - To Test the function of your phone keys.
*#300# - Displays the details about your phone's Hardware and software version
*#311 -Master reset - To revert back to factory settings.
*7 - To unlock your keypad
Feb 19, 2011 | Motorola Mobility RAZR V3
What is the master reset/clear code for the motorola razr v3?
Feb 09, 2011 | Motorola Mobility RAZR V3
Wont recieve calls! razr v3
You may have the profile set on silent with no vibe. alert. Go into settigs, profiles, choose customise and set to a higher volume.
Jun 07, 2009 | Motorola Mobility RAZR V3
Keypad not working during phone call
u'll have to get the keypad checked ...because the connection b/w the buttons and the chipset does seem to be ok.
May 29, 2009 | Motorola Mobility RAZR V3
My keys arent working
Sounds like a worn out keypad google for your area here in ATL I can get the entire housing and keypad replaced on that phone for $20
Jan 09, 2009 | Motorola Mobility RAZR V3
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Motorola v3 razr problem
if ur mobile is under warrenty then contact ur nearest dealer.
Feb 20, 2008 | Motorola Mobility RAZR V3
V3 x problem
the problem is the flex cable.Take it to a technician and for about $15 is will be fix. this is a common problem on v3.
Jul 10, 2007 | Motorola Mobility RAZR V3
Mootorola rzr v3
check to see if your phone lock is restricting your phone dialing out. that will allow you to recieve phone calls but not make any of your own. to check if this is it go to settings, security, restict calls enter your unlock code if you know it or if it has not been changed, outgoing calls and see if it's own allow if not change it. if it's not the problem sorry.
Mar 19, 2007 | Motorola Mobility RAZR V3
RAZr V3 Keypad lighting not working
Settings, Initial Setup,Backlight. Try this. Hope it works.
Nov 02, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
