Question about Raymarine GPS
I HAVE THE RL7OC PLUS. THE PORT TO PUT THE CHART
I HAVE A RAYTHEON RL7OC PLUS. CAN I ALSO USE IT AS A CHARTPLOTTER TOO? THE PORT TO PUT THE CHART CARDS IS THERE BUT IT DOESNT HAVE THE INTERFACE INSIDE.IT IS EMPTY. DOES THIS INTERFACE EXISTS AS AN ADD ON OR I CANNOT REALY USE THIS PORT AT ALL??
  • 43 Answers
You can upgrade the port and the Software by a Raymarine Dealer
Posted on Oct 22, 2009
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Why didn't my Navionics gold card download work?
Your running an elite 7. It's not compatible with navionics platinum.
Sep 04, 2014 | Lowrance Elite-7 HDI...
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
Where can i get memory battery for simrad ce30 chart plotter
There should be a model number printed/stamped onto the battery. Put this number into Google and yuo should have a list of sources. One of the local battery replacement places (like batteries Plus) can match it up or order one for you.
Jul 08, 2013 | Boating
My furuno chartplotter is out about 2 km on the chart how do i correct this problem it is a furuno 1650wf
Make sure your time offset is correct and also make sure you have not accidentally offset the chart. Also keep in mind that there are places in the charts that you can overzoom which can also cause this problem.
Feb 25, 2010 | Furuno 1650wf/Nt...
Can i connect a pendrive to my dvd player which doesnt have a USB port, is there any interface?
No, there's no way to attach a USB pen drive, but you can put movies onto an SD card and put that card in the unit's SD slot.
Feb 17, 2010 | JVC KW-AVX706 Car DVD Player
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
GPS Logo
111 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
