Question about Whirlpool LER5636P Electric Dryer
Dryer Stopped Heating
I have a Whirlpool Electric Dryer, Model #LEQ9508PW0‏. The dryer works fine, however it has stopped heating. I have removed the heating element and it looks brand new and nothing appears to be burned out and all the wires look great. I did buy the dryer used, however I believe it is less than 2 years old. Thanks for the help.
Rich
  • 3 more comments
  • stanleysmith Jul 28, 2009
    Well I do not have a multimeter, however I can go buy one, but would it be safe to bypass the fuse just to check and see if that is the problem or should I go buy the multimeter? Thanks?
    No I agree, thanks for the advise. I assume I can check it without having it plugged in, is that correct? And what should the meter read if it is okay? Thanks again.
    Rich
    Thanks, you have been very helpful.
    President:
  • 1,776 Answers
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Posted on Jul 28, 2009
  • Bruce Canfield
    Bruce Canfield Jul 28, 2009
    NO! Please don't try to bypass anything. Get a multimeter or have someone check these components out for you if you feel uncomfortable doing it yourself. High voltage is nothing to take chances with. I want your dryer to work, but I also want you to be safe so you will get to use it when it's fixed.
  • Bruce Canfield
    No the machine doesn't have to be plugged in to check continuity. Get a multimeter and make sure it is set to measure resistance (ohms) Here is something that might help you. Best wishes.
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer stopped heating Model - wed5500sq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,.,.
Mar 21, 2011 | Whirlpool Dryers
The dryer stopped heating, The fluff air cycle still works but the heating cycles have stopped working. Is there an easy fix, or do I send it to the scrap metal yard?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Whirlpool LER4634J Electric Dryer
Heating element went bad in whirlpool dryer replaced it and worked fine for about 10 minutes then it stopped heating. took element back off and it looks fine help me plz
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Kenmore 84152 Electric Dryer
My whirlpool estate electric dryer stopped heating up. Everything else works fine. Is the problem the heating element ?
heatman101
May 31, 2010 | Dryers
Dryer not heating up
What you do is remove the rear dust cover. It could be the element located to the right, or it could very well be the Hi Limit mounted atop the heating element chamber. fd54e5e.jpg
Jan 18, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer Problems
contact the manufacturer. some parts might need to be replaced already.
Jul 13, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
301 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
