Question about Ford 8n,9n,2n, Tractor Starter With Drive
Cuts out and then quits. In about 10-15 min. will start again.
After an hour or so of bush hogging, my 1968 Ford 4000 tractor will begin to cut out and then completely quit. When there is more gasoline in it, it takes longer to do this but it does do it eventually everytime. After letting it cool off for about 15-30 minutes. it will start but again after a certain period of time, it will stall out again. Also the longer that I let it cool off, the longer before it stalls again. Seems like the muffler is getting the fuel too hot but a friend said that it also could be the carbeurator or a coil.
    President:
  • 986 Answers
I think that cooling off is doing it,I think your gas is filling you carb bowl,remove you carb and take bowl off ,I would buy a kit,I have had problem with the floats sticking or have been damaged by water freezeing,that carb is easy to rebuid you will do good and you will have the pride of fixing it ,good luck and thanks
Posted on Jul 28, 2009
Ford 2000 tractor stalled bush hogging (Too slow near the fence line, no engine prob). PTO was engaged, was in 2nd/high. Cant get it out of gear to restart.Cant lift the bush hog up--cant do anything.
Have someone help you rock the tractor back and forth and see if it lets go ,if not jack up rear wheels and rock them back and forth.
Aug 31, 2016 | Ford Garden
Mahindra 4540 tractor, check engine light flashing, 214 hours on tractor. I have changed all the filters. Tractor runs great but govenor does not work.
the light has come on to protect the engine from a failed governor operation
fix that or have a service technician carry out the repair
Aug 18, 2016 | Light Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Mower runs good for fifteen minutes then the
Mine did this too. THe semi-transparent fuel filter will look like no gas is in it if you have the problem I had. The gas cap on the tank has a tiny breather hole to keep it from coming under a vacuum as gas runs out. Push thru it with a toothpick to clear the hole. That's all it was. But I did have some black debris clogging the filter and had same symptom.
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere 65 mower cuts for about 20 min. then dies, will start right up again, cuts maybe 5 min., dies again
You have a partly clogged fuel line or the vent in the gas cap is clogged.
Sam
Jul 18, 2009 | John Deere Garden
Truck will not start
check to make sure you are getting fuel, when an electric pump heats up they quit working,then when they cool down they might start workig again until it heats up again. or if you have a performance chip in your pcm they short out pull out chip and see if problem is still there
Feb 16, 2009 | 1999 Ford F250 Regular Cab
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
413 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
