Question about NetGear WPN111 RangeMax Wireless USB 2.0 Adapter: WPN111NA (NTUSNGWPN111)
Cant connect to the internet
I cant connect to the internet. We unplugged computers durring a bad electrical storm. I have a laptop computer. When we cut everything back on including the wireless router, I cant get back on line. I am using netgear wpn111
  • 1,272 Answers
Hi, Can you provide some more details:
1. Model number of wireless router?
2. Are you online when connected direclty to the wireless router using ethernet cable.
3. Operating system on the computer with the adapter WPN111.
This will help me provide an effcent resolution.
Posted on Jul 29, 2009
My gateway laptop keeps typing ........... periods or dots.
moved you out of HP. it's not a hp
the does means the key board is bad.
unplug the keyboard, see, it bad.
gateway is defunct maker now, long gone.
hard to find parts but ebay.
Sep 09, 2017 | Gateway Computers & Internet
CANT GET INTERNET ON VODAFONE IN TRINIDAD
contact ther other service provider and see if they even offer internet..you might need a data pakage from them,
Jun 19, 2010 | RIM Research In Motion Blackberry Storm...
Internet connection shows its connected but cant get on the internet
try using a DOS window and type the command ping www.google.com to see if you get a response, this ping command allows you to see the connectivity , if you get a successful pinging then the next step would be to find out if you have a norton internet suite or some other firewall or protection measure between your computer and the internet. also whether you have a cable modem or FIOS router it would be savy to connect the pc directly to the router and unplug any other computer you may have connected. some worms or viruses can prevent your computer from getting to the internet so you cant fix the problem, although everyone discards a physical problem in this case I always bring my own working ethernet cable just in case. actually I always carry two or three patch cords to make sure the problem is really software related and not media related. try posting the output of the command ipconfig/all in some site like pastebin or similar. thank you .
Jan 26, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Internet connections
Change your ethernet cable from DSL to computer Ethernet port.
Jul 21, 2009 | Acer Aspire One PC Notebook
We had a storm and since then I cant connect to the internet...the connection's good but I cant connect (tried IE and firefox-neither worked)
You should try unplugging your router and cable / dsl modem for a few minutes, then reboot your computer.
That's the first and easiest way of fixing it.
Jun 15, 2009 | Dell Dimension 3100 PC Desktop
It says :"you have been disconnected from online servers"
There can be particular issues related
to playing through a router or firewall,
including sharing your internet
connection via another PC. In order to
join or host a Conflict: Global Storm
game from behind a firewall you must
open the following ports (inbound and
outbound):
UDP ports 4658, 6500, 10010,
13139, 27900
TCP ports 4658, 6667, 28910,
29900, 29901, 29920
To host a game from behind a router
with NAT (Network Address
Translation), or a firewall, you will
need to enable ‘port forwarding’ on
the following ports to route data to the
IP address of your PC;
TCP port 4658
If you continue to have problems
connecting to servers or creating
them, try bypassing your router or
firewall by connecting your PC directly
to your broadband connection.
Do not use ALT+TAB and do not enter Windows when multiplayer is running. It will kill the connection to GameSpy servers which are needed for connecting to any internet server.
Apr 26, 2009 | Eidos Interactive Conflict: Global Storm
WRT100 Router doesnt connect to Pc
Have you powercycled the modem, router in that order, before checking internet connectivity?
Mar 31, 2009 | Linksys RangePlus WRT100 Wireless Router
Internet problem
Rerun the network setup wizard on your computer. Make sure all computers, printers, and routers you want to use in the network are turned on and that an internet connection is present. Once you do this your problem should be fixed. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cannot get through internet via ethernet, I Appreciate your help.
You didn't state what kind of net connection you are using, dial-up, cable, sattelite.
If, for instance, you have cable, is the modem connected directly to one computer, or several, via router and ifso on the router is it "wireless" or cable connected?
If you are using anything OTHER THAN dial-up, I recommend, that you unplug the router AND modem, look for "resets" on both, sometimes the reset will look like a small resessed pin that must be pushed on with a pen or toothpick.(hold down for 30 seconds) Leave them unplugged...I would advise 5 minutes, then reconnect cables and power supplys and try again.
If none of this works and you have had electrical storms,(and sometimes wind damages cable if pole mounted) you may have surge-damaged routers/ and or modems. I usually have to reset mine after every lighting storm, and had to replace a damaged router twice. Sadly on another note, I would not recommend vista to anyone, I would however recommend XP media center for computers that have specs for it.
Hope this will help.
Dec 08, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
207 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
