SOURCE: default pin for pairing bluetooth
This varies unit to unit. Most generic codes are "0000" or sometimes, "1234", but it could be different. Which GPS device do you have?
SOURCE: my blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
SOURCE: pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
SOURCE: how to pair my moby to visrolite
1.from off - press and hold the accept button - green button
2.while holding the accept button switch on - press and release microphone
3.when bluetooth indicator turns blinking red/blue, release the accept button.
The kit is now in pairing mode.
4.while in pairing mode access phone and search for devices.
5.when the phone displays list of bluetooth devises select visorlite
6.when the phone asks for the password enter 0000 and OK.
SOURCE: blueant T1 bluetooth headset -
You need to quickly click and release all three buttons together at the same time (do not hold down the buttons). Source: http://www.blueant.com.au/knowledgebase/reset/t1.php Works like a charm...
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
