Question about Sanyo Televison & Video
Sanyo tv won't turn on after a lightning strike.
I have a Sanyo DP52440 television that won't turn on after a lightning strike. I've tried other outlets, the capacitors on the power supply appear fine, and nothing seems particularly damaged (just by looking at it). When I hit the power button, the green light comes on for a few seconds, then turns off and remains off. After hitting the power button, I can hear a very faint, high-pitched sound I believe coming from the power supply. Is this something that replacing the power supply could fix? Or is it better to replace the tv? This tv belonged to a friend of mine, so I'm not sure the exact situation when the lightning struck (though it may have been plugged into a surge protector). Sorry for the lack of details, but I appreciate any insight.
    Top Expert:
  • Sanyo Master
  • 12,962 Answers
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Posted on Sep 16, 2017
Testimonial: "It worked before the lightning strike. Could I just replace the power supply?"
  • richie46 Sep 16, 2017
    If separate part yes. On some sets the PS is part of another board and it is an all in one deal.
SOURCE:
SOURCE: TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Posted on Aug 17, 2007
  • 38 Answers
SOURCE: Screen won't turn on --flashing green/solid green power light
Your main boards are bad. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Posted on Mar 13, 2009
SOURCE: TV set self turn off after few seconds
my tv will not come on
Posted on Jul 12, 2009
leethedeuce
  • 4472 Answers
SOURCE: tv will not come on,
First off what is the exact model of the tv? Secondly do any lights come on at all? Do you have homeowners or renters insurance? then the surge would be covered under that and depending on size of the tv an equivalent size tv it would be worth it to put in a claim. Once I have more information I can assist you further.
Thank you,
Lee
Posted on Aug 17, 2010
gopakumarg43
  • 76046 Answers
SOURCE: Panasonic TH-50PX80U won't work after
Hello
If cable box converter has damaged, there is no question about the main board of your TV. It has been damaged. Before replacing it, you have to check the power supply board also. If the TV has been pluged to power supply, surely there will be fault to it also. We can't predict the exact fault occurs during a lightning, because Trillions of volts are passes nearby. You have connected the TV with cable connection and to the home power supply too.
Just replace the main board first. If it does not hel you, replace the power board too. I hereby send picture of both boards.
gopakumarg43_14.jpgThe first one is main board and the other is power supply regulator board.gopakumarg43_15.jpg
Posted on Aug 20, 2011
Had Lightning strike. TV box destroyed and tv does not get power. Which boards may need to be changed?
The power supply board is the first board to feel the impact of a lightning strike.. Try that one out first.
Jun 21, 2016 | Televison & Video
Where can I get a replacement screen for a sanyo dp52440 tv
The screen itself will cost just a little under what the TV costs. And finding a LCD is almost impossible. I suggest selling the parts inside to reclaim some cash for another TV.
Sep 16, 2015 | Sanyo Televison & Video
52" SANYO dp52440 POWER LIGHT COMES ON AND OFF PICTURE WON'T COME ON
I had a similar problem with a smaller size sanyo, it turned out to be terminal due to cost of repair Vs cost of new TV
Sep 22, 2014 | Sanyo DP52440 52-inch 1080p 120Hz LCD TV...
MY SANYO LCD TV MODEL 24 K 50 WAS OFF WHEN LIGHTNING STRUCK NEAR OUR HOUSE AND SINCE THEN IT DOES NOT TURN ON
Replace or have the powrer supply tested and eventually serviced.
Lightning strikes affect two types of boards in televisions - the power supply by means of entering through the AC line and main boards by means of entering from the external signal sources. External antennas are worst and can totally toast the main board whereas a signal entering through HDMI cable from another device is less likely to be affected by a power surge.
So naturally you start your quest with the power board , which is the usual suspect.
As of right now I do not believe we have an announced service for the power supply board of Sanyo LCD-24K50, but if you do not have any other options you can always try and send the power board for examination/repair through
http://www.coppelltvrepair.com/newservice.
Sep 29, 2013 | Sanyo 42 in. LCD TV
Sanyo dp32648 possible lighting strike, whats needed to fix and a possible cost an can i repair myself?
It wont turn on? Well if it is damaged by lightning the only thing damaged would be the varactors on the power supply. They are there to absorb tremendous surge of electricity. The same way a surge protector works. A worse case scenario is the power supply board is fried up. Then being a non electronic technician you can purchase the whole board or order on line and install them yourself. If you brought it to a shop they will charged you for the labor and the board. Don't buy used boards on the internet because a lot of them are no good in my own experience. Get a new one for about a little over a hundred buck or so.
Jun 26, 2010 | Sanyo DP32648 32 in. LCD TV
Sanyo TV Chassis Series AC5-C20 no sound
check power supply to ic,, it will be 12v from smps..may be fusable resistor has gone
Mar 21, 2010 | Sanyo DS27910 27" TV
8 1/2 month old TV went out.
Take it back to where you bought it if it's still under warranty, they are obliged to fix it!
Jun 17, 2009 | Sanyo DP42848 LCD TV
Televison & Video Logo
149 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
